2004-2006.5 [NCP61]
'05 xA's owner's manual lists wrong bulbs.
Old Dec 10, 2004 | 12:07 PM
matt_a's Avatar
Default '05 xA's owner's manual lists wrong bulbs.
Hmmm...So far, I've discovered two incorrect parts listings in the owner's manual for my new xA. The manual lists the bulb for the storage area (oven) as a "4.9watt double-ended" bulb. That's not right. I took it apart and changed it last night. The bulb is a standard #194 bulb which is a single-ended wedge type bulb. Also, according to the owner's manual, the headlight bulbs are a HB2. While that's not entirely wrong, most people will not find a HB2 listed or available at the store. The bulb is a standard 9003. I bought and installed Silverstars last night, and they are #9003ST. Turns out (according to Sylvania/Osram customer service) the HB2 designates the type of bulb, but the number you need to look for in the store is the 9003. Hope this helps.
Old Dec 10, 2004 | 04:19 PM
Toonces's Avatar
H4, HB2 and 9003 are all the same bulb type.
Old Dec 10, 2004 | 04:31 PM
matt_a's Avatar
I see. I didn't know that. Go into an autoparts store or the automotive section of a department store and try to find a HB2. The owner's manual should list the bulbs by the number that people will need to look for. Almost all of the major manufacturers here in the US list that bulb as 9003.
Toonces's Avatar
here is a link with some more info:
http://www.candlepowerinc.com/pdfs/H4_9003.pdf
Old Dec 10, 2004 | 04:50 PM
matt_a's Avatar
Wow...everything you ever wanted to know about H4/HB2/9003 headlight bulbs. Thanks! Where were you with this info yesterday?
Old Dec 10, 2004 | 07:33 PM
fugeelama's Avatar
Also worth checking out:
https://www.scionlife.com/forums/viewtopic.php?t=7225
It's got the bulb sizes for the xB, but they're all the same for the xA too. Also has feedback from xA owners about the bulb for the "oven".
Old Dec 11, 2004 | 06:38 AM
bensonwrx's Avatar
9003 or H4 bulbs will fit the Scion xA, as they are same as HB2. I believed the HB2 means the housing of the headlight is constructed a little differently compared to H4; however, the bulb spec remains as same.
Also, the 194 bulbs also can be called other model numbers as well...had all the bulbs changed in the xA and wife is very happy
MRE
Feb 16, 2016 11:26 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
pier0723
Scion tC 1G ICE & Interior
Dec 3, 2014 03:38 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
Strader
Oct 1, 2003 03:23 PM
