My MIL indicator Light Is on scanner reads PO172
Originally Posted by Syldrin
now that i look at his profile. he's probably building boost at partial throtle and it's throwing his ECU off because he has an ultimate emangle
PS Im selling 2 blackbox if anyone interested..
no...what's happening is when the BOV goes off, all the metered air goes out and the fuel that the ECU has already pushed to go with that metered air makes the car run supper rich, which triggers the 02 sensor to think your cat's not working which throws the code.
This is why they say you SHOULD be able to clear your code, go to the station without hitting boost and pass smog.
The CEL your talking about is during closed loop operation. If the short term fuel trim makes a major adjustment to the long term fuel trim then it throws a CEL. If you clear it and it doesn't come back then NP but if it does come back then pro tune with a scanner to read fuel trims , if you can tune closed loop - see above.
