My MIL indicator Light Is on scanner reads PO172
Originally Posted by Mr_Meaty
So you think with the f/ic we should be able to tune to not get CEL without the anti-fouler trick? even with no cats?
If the short term fuel makes an adjustment greater than 10% (not positive on the percentage) then a code is thrown and then the CEL lites up.
Now back to your question.
Question 1
The CAT that is in the header has an O2 before (bank 1 sensor 1) and one after (bank 1 sensor 2). The first O2 is for feedback to the ECU and the second is to see if the CAT is working. Since it appears that his issue is with the bank 1 senor 1 it is the first O2.
Question 2
Removing the first CAT of course is common with us FI TC's and can not be fixed via fuel trims. Removing the second CAT does not throw any codes.
I'm no expert and if anyone has more please pipe up.......
right...I have not cats but I did not have a CEL before my newest tune...turns out my 02 sensor was bad enought to not read properly but not bad enough to throw a code, which is why I could nto tune right but would not throw a code.
I thought that one of the thigs the f/ic 02 table did was intercept the voltage that bank2 sent to bank1 so that it would trick the sensor into thinking the primary cat was working properly.
If that is the case, and the only code you have is the P0420 cat inneficiecny code, you should be able to get rid of that by altering the voltages in the 02 table, right? either that or use anti-foulers...
I have a different understanding of the O2 map (and I could be wrong) . I thought that what you set in that table is what you wanted the AFR's to be during closed loop and then you would have to match that table to the fuel table to accomplish the AFR. if not then CEL comes on.
I know this gets confusing.........
After reading up on P0172 I believe that Mr Meaty is correct that this code can either be the fact that he is missing the first CAT or his fuel trims are off, as stated earlier. There are two ways to trouble shoot. First put in an anti-fouler extension on the second O2 and see if code goes away or get a hold of a scanner that can read fuel trims and see if the short term fuel trim making major adjustments.
I have antifouler an I believe it is working fine, the reason why my cel came on because my bov was venting to atmosphere which trigger all sensor that monitor the fuels. I recirc the bov back to intake an reset ecu. now 200 miles still no light, I also pass the obd 2 computer test for emission. my car has no cat, thank god to the 3 dollar antifouler mod. thanks for the help from all u guys.
Originally Posted by Ace83
Originally Posted by java09
Originally Posted by Syldrin
now that i look at his profile. he's probably building boost at partial throtle and it's throwing his ECU off because he has an ultimate emangle
PS Im selling 2 blackbox if anyone interested..
P0172 is a Catalytic converter code.
^^ the blackbox did make the part tune richer but not perfect using the base tune.. the aem fic has an o2 spoofer that you can tune that alters the feedback of the O2 sensor to the ecu so close loop tune can be altered, that by tricking the ecu.. but yeah the perfect and right way is to go standalone
Here's the write up on the AEM site about closed loop tuning........
O2 Feedback with the 05-06 Scion tC
Boosted Scion tC owners who want to enrichen the fueling at partial throttle settings when the factory ECU is in feedback mode can do so with the F/IC. The Factory ECU tries to run the engine at stoich (~14.7:1 Air/Fuel) when it is not at full throttle. However, forced induction tC's can make boost while still at partial throttle and the ECU is still in feedback mode. 14.7 is TOO LEAN to be running when under any appreciable boost and can cause stumbles.
The Scion tC has a uncommon O2 sensor style but the F/IC can still modify your target AFR's. It is assumed that you have the F/IC hooked up per the recommended connection diagram from AEM. It is also assumed that you have an independent AFR device to confirm the proper operation. It doesnt have to stay on the car but it is valuable during setup to confirm proper operation.
Step 1:
Open the Setup dialog box
In the O2 sensor section (top right)
Load Input = MAP (Sets the Y axis of the O2 map to the internal MAP sensor)
Mode = Voltage (says the table will contain raw voltages)
Period = Not applicable for Voltage mode
Bank1 Hi voltage = 4.95
Bank1 Lo voltage = 0.0
Now open the O2 Map by either clicking on the icon with the big "O" in it or select "O2 Map" under the maps menu.
The O2 Map is a 21 RPM (X Axis) by 17 Boost (Y Axis) table. In each cell is the voltage you want for each operating point (The F/IC interpolates between the 4 nearest breakpoints for smooth transitions).
Set up the load axis by clicking on each breakpoint and setting it to whatever you want. You can also drag a bunch of them and it will interpolate between the end points. Do the same with the RPM. These two sets of breakpoints are unique to this table so changing them wont change them in other tables.
Enter the desired closed loop AFR target into the cells of the table using the following values.
AFR Value
17.4 4.0
17.0 3.9
16.6 3.8
16.2 3.7
15.8 3.6
15.5 3.5
15.2 3.4
14.9 3.3
14.7 3.2
14.4 3.1
14.2 3.0
14.0 2.9
13.8 2.8
13.6 2.7
13.5 2.6
13.3 2.5
13.2 2.4
13.1 2.3
13.0 2.2
12.9 2.1
12.8 2.0
12.7 1.9
12.6 1.8
12.5 1.7
12.4 1.5
12.3 1.4
12.2 1.3
12.1 1.2
12.0 1.1
11.9 1.0
So if you want 13:1 AFR in a particular point, put 2.2 in that point in the table. Some minor tweaking may be required but these values will get you VERY close. As long as the factory ECU is in feedback then these values will be used.
IMPORTANT:
If you just change the target AFR, the factory ECU will adjust the trims to achieve the desired AFR. BUT, if you make huge changes then you will get huge trim corrections and the chance of a check engine code for excessive trims. Dont forget to adjust the fuel maps to add the approximate amount you are requesting here. That way the trims will stay near zero!
Step 1:
AFR Value
17.4 4.0
17.0 3.9
16.6 3.8
16.2 3.7
15.8 3.6
15.5 3.5
15.2 3.4
14.9 3.3
14.7 3.2
14.4 3.1
14.2 3.0
14.0 2.9
13.8 2.8
13.6 2.7
13.5 2.6
13.3 2.5
13.2 2.4
13.1 2.3
13.0 2.2
12.9 2.1
12.8 2.0
12.7 1.9
12.6 1.8
12.5 1.7
12.4 1.5
12.3 1.4
12.2 1.3
12.1 1.2
12.0 1.1
11.9 1.0
IMPORTANT:
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
cid_mcdp
Jan 5, 2015 02:45 PM
hotroddelux
Dec 3, 2014 11:33 PM
