Scion tC 08 having trouble installing the H.I.D. Conversion..
Old Aug 4, 2008 | 05:44 AM
santana0304's Avatar
Default Scion tC 08 having trouble installing the H.I.D. Conversion..
I got my kit this weekend it took off the head put didn't fit in the instruction it says that I have to cut out a piece of head light from my low beams. So anyone out there
that could help me out I would appreciate it and if you got pics of a site where it shows how to do it that would be even better. I tried YouTube but that didn't work out at out.
___
Old Aug 4, 2008 | 05:57 AM
BlizZard's Avatar
WHAT?! no bro, dont cut anything, i didnt...
what hid kit do you have?
Old Aug 4, 2008 | 05:59 AM
MisterKe's Avatar
I'm not too sure about the 08 projector headlights, but I'm pretty sure you don't need to cut anything. AT ALL. Except maybe for excess zip tie. It should plug and play.
Old Aug 4, 2008 | 06:17 AM
SuperMario6582's Avatar
no cutting required on the 08 projector headlights with a plug-n-play hid kit. my girl got a set for hers and they plugged right in.
Old Aug 4, 2008 | 06:27 AM
tkevin07's Avatar
Yea I sell them they say u need to cut the rubber grommets but the tC doesn't need to
nor has them they should plug right in. Try to see if the size is right with ur stock bulb.
___
Old Aug 4, 2008 | 09:17 AM
Agent99's Avatar
Which kit do you have? How much was it? What color?
Old Aug 4, 2008 | 09:51 AM
SleePi's Avatar
i dont know about you.. but for my HIDs they are plug and play. but it didn't fit becaues the rubber ring around the bulbs were big, so i had to swap it with the stock bulb's ring. that could be why it doesn't fit.
Old Aug 4, 2008 | 06:43 PM
I bought my kit from mod-express they have a pretty good deal right now 140 but its 150 with the relay hardness i got that too because i didn't know if ima need it out not so there goes another question do i need that relay harness? i also have a question about those two blue and black white that are on the bulb are they connected or what? i go tthe 6000k i didn't want to goo too extreme with the blue i wanna do a custom green paint job. If anyone could help me with some pictures i would really appreciate it big time.....
Old Aug 4, 2008 | 06:48 PM
SquallLHeart's Avatar
the relay harness is a good idea to install with the kit
i'm still trying to figure out why the instructions tell you to cut something and why it doesn't fit right in.
Old Aug 4, 2008 | 07:26 PM
wazzu_coug's Avatar
USE THE RELAY HARNESS! If you don't you risk frying your factory harness. No bueno.
I'm not quite sure what your saying doesn't fit. The bulb or the wiring harness? You should have ordered the H11 (2008-2009 tC) size kit. If you accidentally ordered the 9006 (2005-2007 tC) the bulbs will not fit the factory wiring plug. If I remember correctly, they will fit into the housing though. Most companies will just give you a 9006 bulb and an adapter wiring piece to connect it all. So I'm going to guess thats what they did. You must use the relay harness to connect everything. Bulb to the relay harness, then using the adapter wiring to connect to one of the factory bulb plugs, as a signal to the relay.
Old Aug 4, 2008 | 08:43 PM
OK i go thte relay part now so i do have to use that hardness which now im glad i did order it with the kit. Okay that part i got done right. I did order the correct bulbs like you said H11. but i do see that the bubl has two wires sticking out of them what do i do with those wires? i can't figure out where the hell those two wire are connected to.
Old Aug 4, 2008 | 09:32 PM
HomelessGuy's Avatar
Connect the wires to the ballasts. The part about cutting may just be the dust cover/
grommet that comes attached to the new lights, the tC doesn't use it. i just left mine on.
__________________
Old Aug 4, 2008 | 10:13 PM
do you have any pictures you could show me on the install. I still dont understand where too connect that blue and black wire that is on the bulb. Sorry to bug you guys about this topoic but i dont want to ruin my eletrical wiring.
Old Aug 5, 2008 | 01:59 AM
tkevin07's Avatar
take a pic of ur kit and ill figure it out for u =D
Old Aug 5, 2008 | 02:47 AM
well all i need to know is which wire on the headlight switch is the positive or the negative the gray one with a white strip or the white one with the black strip
Old Aug 5, 2008 | 04:17 AM
i bought my kit from mod-express.com with the relay harness.
Old Aug 5, 2008 | 05:11 AM
wazzu_coug's Avatar
the wires coming from the bulbs should plug into the ballasts. there should be three tails (besides the power and ground) coming from the relay. two of them go to the ballasts, and the third plugs into the stock bulb's socket.
when i got my kit, they said that at that time, no one made a H11 harness, so they just use a 9006 harness and use an adapter that goes in between the relay and the stock bulb's plug.
check out mobilehid.com's instruction page. it may help.
http://www.mobilehid.com/support.htm
Old Aug 5, 2008 | 06:12 AM
the relay harness that is show in that link you offered me thats the exact one i have where would i get the adapter if thats not the right relay hardness? it seems like i only have to figure out which of the red and black wire go to the actually headlight switch
Old Aug 5, 2008 | 07:04 AM
wazzu_coug's Avatar
wait what?
in the picture of the harness:
the red wire (power wire) connects directly to the positive side of your battery.
the black single wire (ground plug) connects directly to the negative side of your battery.
the two plugs that are labled "ballast plugs" connect to the ballasts. logically, the longer one to the passenger side.
the "remote turn-on plug" connects to the factory headlight bulb's plug. the one that you would normally plug the headlight bulb into.
the HID bulbs should have a plug coming out of them. those plug into the ballasts.
Old Aug 5, 2008 | 03:25 PM
yea i got all those in placed i believe but theres just two specific wires i dont know what to do i believe they go into the remote which so the head light could turn on but i dont know which of the factory hardness is - or +. but i do have the rest the way you explained it well at least the way you word it out for me. appreciate all the help you are giving me.
