idling problems on new turbo install - PLEASE HELP!
Old Aug 6, 2008 | 10:30 PM
xa007xa's Avatar
Default idling problems on new turbo install - PLEASE HELP!
completed motor swap with greddy turbo. running emanage basic and have put about 300 miles on it so far. everything was working normal until today. i havent driven it since sunday. the car is idling at 2500 rpm. it starts out going between 500 and 2500 rpms like its trying to find the right rpm to idle at but it ultimately idles at 2500 rpm. i took emanage out of the picture and same problem happens with stock ecu. no check engine light. accelerator pedal is free and so is throttle cable. did emanage corrupt my stock ecu? need help desperately.
Old Aug 6, 2008 | 11:13 PM
SimonTrent's Avatar
I'm sure there could be many things that could be wrong, but in my limited info to share, have u tried checking your spark plugs? If 1 or more of your plugs are not firing your engine will idle higher and would have a strong gas smell from your exhaust. Hope this helps
Old Aug 6, 2008 | 11:47 PM
xa007xa's Avatar
code p0505: Idle Speed Control Valve. Luckily I have a spare sitting around!!! will mess with it tomorrow. Such quality parts from toyota. Fails after only 32000 miles.
Old Aug 13, 2008 | 03:42 AM
bob_sagat's Avatar
How do you like the turbo kit? Can you feel a big difference in power?
Old Aug 13, 2008 | 12:50 PM
JSosa's Avatar
I was going to tell you to check the ISCV because when i had the engine head removed and my mechanic cranked the car for the first time it idled fine for 10 min then it went wacko, just like what your saying. We checked a couple of things but eventually we found out it was the ISCV.
Another thing you can check are the 2 sensors that plug into the throttle body which would also cause irradic idle. If they are not connected, there is your problem./
xa007xa's Avatar
turbo is nice. helps to have the lsd too. running 10psi with emanage blue. will eventually get ultimated tuned. not good on gas mileage tho. I haven't had the chance to do a 0-60 test yet. was doing 9 seconds before turbo.
Old Aug 13, 2008 | 12:59 PM
firesquare's Avatar
what kind of motor swap are we talking about?
your running 9's before a turbo?!? you have proof of all this?
Old Aug 13, 2008 | 01:15 PM
xa007xa's Avatar
0-60mph in 9 seconds. not 1/4 mile! I built a 1nzfe for the turbo.
Old Aug 13, 2008 | 01:17 PM
firesquare's Avatar
ahhhhhhhh ok. sweet. do you still have the VVT-i? if you do maybe thats affecting idle?
Old Aug 13, 2008 | 01:22 PM
xa007xa's Avatar
bad idle speed control valve. problem fixed.
Old Aug 13, 2008 | 01:23 PM
firesquare's Avatar
do you have a post on your motor build up? how much PSI and stuff like that?
Old Aug 13, 2008 | 01:43 PM
xa007xa's Avatar
search for "beefing up 1nzfe started"
my06tc
Jun 25, 2015 12:18 AM
cid_mcdp
Jan 5, 2015 02:45 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
