idling problems on new turbo install - PLEASE HELP!
completed motor swap with greddy turbo. running emanage basic and have put about 300 miles on it so far. everything was working normal until today. i havent driven it since sunday. the car is idling at 2500 rpm. it starts out going between 500 and 2500 rpms like its trying to find the right rpm to idle at but it ultimately idles at 2500 rpm. i took emanage out of the picture and same problem happens with stock ecu. no check engine light. accelerator pedal is free and so is throttle cable. did emanage corrupt my stock ecu? need help desperately.
I'm sure there could be many things that could be wrong, but in my limited info to share, have u tried checking your spark plugs? If 1 or more of your plugs are not firing your engine will idle higher and would have a strong gas smell from your exhaust. Hope this helps
Originally Posted by xa007xa
code p0505: Idle Speed Control Valve. Luckily I have a spare sitting around!!! will mess with it tomorrow. Such quality parts from toyota. Fails after only 32000 miles.
Another thing you can check are the 2 sensors that plug into the throttle body which would also cause irradic idle. If they are not connected, there is your problem./
turbo is nice. helps to have the lsd too. running 10psi with emanage blue. will eventually get ultimated tuned. not good on gas mileage tho. I haven't had the chance to do a 0-60 test yet. was doing 9 seconds before turbo.
my06tc
Jun 25, 2015 12:18 AM
cid_mcdp
Jan 5, 2015 02:45 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
