06 scion tc burning oil
Old Aug 9, 2008 | 05:42 AM
DaKidd718's Avatar
Default 06 scion tc burning oil
has anyone had this problem i took my car to dealer they did an oil change and codes were cleared. check engine light had come on after about 10 miles of driving then turned off until i put another 100 miles on the car. i checked the oil level today motor was nearly dry. its going bac to the dealer any ideas if warranty will cover it and qhy the car is burning oil???
Old Aug 9, 2008 | 05:43 AM
equinox2355's Avatar
What mods have you done?
Old Aug 9, 2008 | 05:47 AM
Kanchi's Avatar
How many miles..have you done any maint?
Old Aug 9, 2008 | 07:28 AM
TylerC08's Avatar
Adding to all the other questions...
What motor oil are you using?
Old Aug 9, 2008 | 09:34 AM
tCtCtC's Avatar
really not helpful if you dont mention mods...
Old Aug 9, 2008 | 01:57 PM
Ace83's Avatar
Ronin Scion
to add to the questions above, do you have oil leaks or see some blue/whitish smoke on you exhaust?
Old Aug 9, 2008 | 04:26 PM
Jon's Avatar
Jon
Moderator
Moderator
Did you notice any oil in the driveway/where you park?
Old Aug 10, 2008 | 01:07 PM
jct's Avatar
jct
need more info on this!!!
Old Aug 10, 2008 | 02:33 PM
I am almost tempted to say it was a troll
Old Aug 10, 2008 | 08:40 PM
justin6969's Avatar
guess he didint wanna kno but
check for oil leak's
what oil are you useing / how many mile's on the car
what mod's u got
and what were your check engine light code's?
gotta give more detail not just
" some one stole my oil?"
Old Aug 10, 2008 | 10:45 PM
TeeCizzle's Avatar
Mines a 06...
When I drain the Old Oil out I notice it only fill about 2 3/4 bottles when pouring the used oil into the quart bottles for disposal.....Weird!......good thing it Full Syn. Oil
Old Aug 12, 2008 | 03:10 AM
DaKidd718's Avatar
no performance mods at all last engine codes i remember were something about the camshaft gear, misfire in cylinder 4 system to lean nd another one about the catalytic converter. i got jus under 36000 miles nd i use 5w30 toyota oil all scheduled maintaince has been done to my knowledge. wen my father gave me the car with 20k the pcv valve hadnt been changed but now i change it wit every oil change.
Old Aug 12, 2008 | 03:13 AM
Ace83's Avatar
Ronin Scion
but did you see oil leaks like in your driveway or where you park the car or do you see excessive smoke on your exhaust?
Old Aug 12, 2008 | 03:15 AM
DaKidd718's Avatar
no oil leaks as for as smoke a lil here nd there
Old Aug 12, 2008 | 03:20 AM
Carlanga's Avatar
why change pcv valve on every oil change? not necessary that often
Old Aug 12, 2008 | 03:23 AM
DaKidd718's Avatar
its only 5 bucks i figured why not change it frequently the dealers says to change it every 15k
Old Aug 19, 2008 | 08:26 AM
hunterUnknown's Avatar
pretty easy change to do this pcv valve? i have to change mine. i havent really looked into how to do it but any tips? instructions?
Old Aug 20, 2008 | 05:16 AM
mb2008's Avatar
Always possible the dealership didn't fill it up too. You should check the oil the same day you get it changed after the motor is cool.
Old Aug 20, 2008 | 05:20 AM
just kdding. it was way easy.
Col168c
Jan 8, 2015 06:30 PM
cid_mcdp
Jan 5, 2015 02:45 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
eric_m
79
Mar 17, 2013 12:21 AM
BlueBox
22
Nov 7, 2003 08:18 PM
