do i need to change my camper kit
Old Aug 9, 2008 | 08:12 AM
rambo's Avatar
Default do i need to change my camper kit
ei guys!!! i just ordered hotchkis lowering spring.do i need to change my camper kit too???
Old Aug 9, 2008 | 08:25 AM
05FMtC's Avatar
Default Re: do i need to change my camper kit
i think you are refering to a camber kit. correct?
Old Aug 9, 2008 | 08:39 AM
TylerC08's Avatar
Some have got the alignment back to OEM specs w/o a camber kit. The rear suspension is a bit difficult to get back to OEM specs the lower you go.
Edit: This thread was posted not to long ago and will answer all your questions/concerns...
https://www.scionlife.com/forums/vie...r=asc&&start=0
Old Aug 9, 2008 | 09:23 AM
rambo's Avatar
hehehe my bad!!!!yeah i mean camber!!!!
Old Aug 9, 2008 | 04:47 PM
engifineer's Avatar
Is it a 5th wheel or a pop up?
Old Aug 9, 2008 | 05:01 PM
TylerC08's Avatar
Lozln
Old Aug 9, 2008 | 05:22 PM
yellowxhoodie's Avatar
Old Aug 9, 2008 | 08:26 PM
CDogbert's Avatar
I see I was beaten to it.
Old Aug 9, 2008 | 10:07 PM
jackotamo's Avatar
Some people say you need a camber get the lower you go, I guess it depends on the guy who is doing your alignment. Im on s-techs and I just installed them myself yesterday, I went to NTB and he was able to get it back in the spec.
Old Aug 10, 2008 | 12:15 AM
engifineer's Avatar
He probably ground slots in your struts to do it.
However, you can run -2 degrees if you want with no abnormal wear.. I do. Handles much better that way, which I need for autox. But, you still need to have it aligned to correct toe.
Old Aug 10, 2008 | 03:06 AM
a_german_named_hans's Avatar
When i got my hotchkis installed, camber was way out. I got it aligned and my tech (was actually one of the cooler Toyota techs I've ever had, actually knew stuff about turbos beyond what toyota says) said that the front he was able to get back into spec however the back was a little out of spec. He said it was so minimally out of spec that it wouldn't effect the car negatively.
Old Aug 10, 2008 | 03:17 AM
jamie1tc's Avatar
what up engifineer? Still lovin my cluster every day! I have a Hotchkis set up and you need the camber kit. Call Hotchkis they'll tell ya.
Old Aug 10, 2008 | 03:25 AM
^^ I've been rollin on Hotchkis for over a year and I've got no uneven wear. I don't see why you would need a camber kit.
Old Aug 10, 2008 | 04:05 AM
jamie1tc's Avatar
Then who cares?
hampton1100
May 28, 2015 07:32 AM
Ksn
Feb 4, 2015 02:10 AM
scsteven
Jan 25, 2015 01:06 AM
mrsocks
Jan 20, 2015 01:29 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
