extending antenna wire to relocate antenna???
Old Aug 9, 2008 | 06:11 PM
gear7's Avatar
Default extending antenna wire to relocate antenna???
just out of curiosity, have anyone extended their factory antenna wire and relocated the antenna? my main concern is if i cut the stock antenna and reconnect it, i might lose some reception. any thoughts on this would be greatly appreciated.
Old Aug 9, 2008 | 08:59 PM
g_what's Avatar
where and why do you want to move it?
Old Aug 10, 2008 | 12:43 AM
foose801's Avatar
Utah Scions
you gonna shave it? nice.
in all honesty there are plenty of ways to extend the cable, just cruise by any car audio shop and pick up and extension.... don't cut the cable (it's a coax and is super lame to repair)
you won't necessarily notice in change in reception unless you stash it in a crazy place. personally if i were to shave mine it'd be stashed in the rear fender above the wheel well, just inside where i'd be takin it off to shave
Old Aug 10, 2008 | 01:52 AM
gear7's Avatar
darn.....i should've read your post before i cut the cable. one of the wire is a coax with one wire inside the other. i guess i'm out of luck trying to extend it with a regular wire. any ideas on how to fix this? i was planning to relocate the antenna up higher inside the c-pillar and shave the antenna hole.
Old Aug 10, 2008 | 01:59 AM
a_german_named_hans's Avatar
what if you were to place it in the A Pillar and rather then extending it, you'll shorten it?
Old Aug 10, 2008 | 05:58 PM
foose801's Avatar
Utah Scions
^ that's a great idea, if you don't have front side-curtain airbags.
coax cable IS one inside the other. it can be repaired, but it just kinda sucks and is time consuming. you'll wanna solder the inside pins together (the one you cut onto an extension coax cable) then take the shielding from those cables and solder em together.
however, antennas are cheap, and so are coax cables. cruise by a best buy and pick up a cheap rubber antenna, or better yet they have an amplified window antenna that you can pick up, grab a 12' extension and run a comletely new antenna from your headunit to your desired mounting location.
good luck!
Kata
Mar 2, 2015 10:46 PM
ONE_HOT_BOX
Feb 19, 2004 02:04 AM
betlog
Feb 18, 2004 03:30 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
TJ
Nov 6, 2003 01:16 AM
