Question about Subs Pulsing
Old Aug 17, 2008 | 03:08 PM
STNC's Avatar
Default Question about Subs Pulsing
Hi Everyone,
I just put my subs back in, and now whenever my car turns on, the pulse at full volume for like 2 seconds....
This happened once or twice before I took them out, so far its happens every time since I put them back in...
Setup:
2 13Kv4 eD Subs
1 NINe.2x Amp
4 Gauge KnuKonceptz Wiring Kit
07 Stock Premium Headunit
Old Aug 17, 2008 | 03:12 PM
Tcguy85's Avatar
stock hu?
Old Aug 17, 2008 | 03:14 PM
STNC's Avatar
Old Aug 17, 2008 | 03:25 PM
Tcguy85's Avatar
oh, i see. sorry.
i would double check all the wiring up front at the HU. it seems like a wiring issue somewhere. maybe a bad ground. just check everything over.
Old Aug 17, 2008 | 03:29 PM
STNC's Avatar
Roger that!
Thanks! For the Help!
I wrote it a little confusing about the HU, its my bad!
Old Oct 4, 2008 | 12:37 AM
STNC's Avatar
Bump!
Still not getting anywhere
Old Oct 4, 2008 | 01:16 AM
joshrobb08tc's Avatar
problem shoot it. first try takeing one of the rca's out turn the car on and see what happens, then try the other one, then try them out all together.
next make a new ground to bare metal chassie away from your last one.
Old Oct 4, 2008 | 01:21 AM
i know the new premuim stock decks have rca inputs but did you use a line output converter?
Old Oct 4, 2008 | 01:23 AM
STNC's Avatar
the 08's + have the rca
I am using a line out
and what am i grounding again?
Old Oct 4, 2008 | 01:30 AM
make a new ground for the amp. ground it to the chassie of the car, strip all paint away, then use self tapping screws to secure to the chassie(under rear seat is a good place). check clearance dont go through your gas tank lol
Old Oct 4, 2008 | 01:32 AM
how and were is it grounded to now?
Old Oct 4, 2008 | 01:36 AM
oh wait you just said you are usesing a line output converter? if thats the case then you need to adjust it and turn it down. let me ask you this when the car is on and you turn just the deck off does it make the same sound?
STNC's Avatar
Its grounded on a natural looking eyehook thing at the moment... I can get some pictures tomorrow
So even though the amp may work its not properly grounded?
STNC's Avatar
It makes the sound when I use my push button start
Old Oct 4, 2008 | 01:37 AM
thats correct!!!!!!
Old Oct 4, 2008 | 01:39 AM
take the ground away from anything else and make a new one yourself just like i explained usesing self tap screws and star washers i bet it fixs your problem!!!!
Old Oct 4, 2008 | 01:41 AM
im leaving work so ill check here tomarow night around 7 pm. good luck!!!!!
Old Oct 4, 2008 | 01:50 AM
STNC's Avatar
Ok, where did you ground yours?
Should this fix my problem with the line out wire for my underbody kit?
Old Oct 4, 2008 | 07:35 PM
thier are a ton of options under the back seat. the bottom half of the back seat just pops right up thier is a metal brace that goes all the way across and that will work fine!!!! just make sure you use the salf tapping screws and star washers.
Old Oct 4, 2008 | 07:40 PM
STNC's Avatar
I need something relatively accessible from the hatch area
Also, since you are MECP, how do I tap an RCA, that is my main problem, apparently tapping the front speakers wont work for my underbody. Do i just need to strip the wire a bunch and put it in between the male and female RCA Plug?
