Help with HKS EVC boost controller !!! PICS ( 56k no go )
Old Aug 18, 2008 | 05:53 AM
RusWolf's Avatar
Default Help with HKS EVC boost controller !!! PICS ( 56k no go )
Hello guys.
I got the HKS boost controller basically free with when i picked up my turbo kit.
It apprears to be used. I honestly have no idea whats supposed to be in the package and what gets mounted where.
I took some picture of the whole thing so maybe you guys can tell me if its a complete package or not , if not what else do i need ?
also , how can i check if the controller even in good operating condition ?
here we go pics:
Old Aug 18, 2008 | 10:33 AM
Ace83's Avatar
Ronin Scion
^^ check the HKS site and look for manual, but i think they pretty much just bolt up.. the lil vacuum block though you need to find out which one goes the vacuum source and which one goes to the wastegate
Old Aug 18, 2008 | 01:50 PM
B_Real45's Avatar
HKS manuals are usually all in Japanese.
The hardest part is finding out the designations on the stepper motor.
I would go to DSMTalk or Honda-Tech and ask people who use this controller.
Old Aug 18, 2008 | 01:55 PM
Ace83's Avatar
Ronin Scion
^^ you're right lol.. yeah check out forums! like DIYs
Old Aug 18, 2008 | 02:15 PM
RusWolf's Avatar
whats that mean ?
Old Aug 18, 2008 | 02:56 PM
xceptionalauto's Avatar
The larger port on the outside is the controller hose that will go to wastegate. The center is the one that gets the boost source( close to turbo as possiblej). The outside smaller port goes to intake manifold. Looks like you have everything except the wire harness that connects the stepping motor to the unit. Very good boost controller
Old Aug 18, 2008 | 03:08 PM
B_Real45's Avatar
Xceptionalauto got it.. he knew which ports are which.
All you need to do now is hook up the vac/boost lines as xceptionalauto has stated, then wire the unit to the stepping motor.
Old Aug 18, 2008 | 04:57 PM
RusWolf's Avatar
Thanks for the help guys !
ANy ideas where can i get the wire harness to connect to the stepping motor to the unit ?
also, are there any mounting hardware needed, clips ? bolts or anyting ?
Old Aug 18, 2008 | 05:07 PM
There are no other important parts. You can make a harness just match up connectors and run wire accordingly. Im sure I can find you a harness if needed.
Old Aug 18, 2008 | 05:15 PM
RusWolf's Avatar
that would be good if its not too expensive i would just buy it.
Aslo just by using a picture that i provided can you number what goes where ?
and which part is which ?
cuz i'm really a noob with boost controllers.
Old Aug 18, 2008 | 05:26 PM
B_Real45's Avatar
What you have is the HKS EVC EZ-II
And look what I've found for you..
http://www.hksusa.com/info/download.asp?id=3374#
Old Aug 18, 2008 | 05:27 PM
B_Real45's Avatar
Ace had a good suggestion from the beginning..
But HKS was notorious for having terrible US support.. but apparently they've fixed that recently. Now it's easier to find US instructions for their products.
Old Aug 18, 2008 | 05:46 PM
Not sure what else to tell you without hooking it up for you. The control units go in the car mount were you prefer. The stepping motor mounts under the hood away from heat. Connect the hoses like I stated before. The wires in the car are power and ground. I sent hks email about harness, they dont list the part but we will see what they say. If you do hard wire just pay attetion to harness connector cause some of them are not just color to color. Just make sure you look at the way it would plug together and wire accordingly
Old Aug 18, 2008 | 06:05 PM
RusWolf's Avatar
Oh sweet, thanks for the find man !
only things is i'm lookign at the file right now and in parts list i dont see that screen as shown in my last picture.
i guess its a package or something where screen is separate .
Old Aug 18, 2008 | 06:11 PM
RusWolf's Avatar
Cool, thanks for the help man.
I definately need the most information i can find about how to install this thing so i can take everything to tuner so i can get tuned for 2 settings.
Old Aug 19, 2008 | 01:27 AM
RusWolf's Avatar
Is there a way to check if the unit is working ?
or i have to wait till proper install of everything.?
Old Aug 19, 2008 | 01:28 AM
B_Real45's Avatar
You can use a 12v source to see if the unit turns on.. other than that, I think you may need to really install it.
Old Aug 23, 2008 | 09:10 PM
RusWolf's Avatar
xceptionalauto
Did HKS replyed to your email about the harness ?
Old Nov 3, 2008 | 03:47 PM
GTS-T's Avatar
Ruswolf,
What's the status? I'm want to get a HKS timer and HKS EVC for my tC but I want to see if they can be installed first.
Old Dec 19, 2008 | 09:34 PM
RusWolf's Avatar
sorry for old reply i was not available due to training...
but the status remains at 0 , as i never got the chance to install anything yet. will install when i'll be done with AIT .
tckid21
Mar 12, 2017 09:16 PM
YooItsJay
Dec 2, 2015 08:13 AM
my06tc
Jun 25, 2015 12:18 AM
cavalierkid888
Jan 8, 2015 04:42 AM
spawnconnery
Dec 18, 2014 08:38 PM
