tC spare tire??
Old Dec 15, 2004 | 09:28 AM
yankeeintruder's Avatar
Default tC spare tire??
Just test drove a tC the other day......... SCHWEEEET!!! I looked it over pretty well but forgot to look at the spare tire .
I'm assumming it's a doughnut............ if it is....... will a full size wheel (17") and tire fit in the spare tire well??
Old Dec 15, 2004 | 09:59 AM
HeartBreaker's Avatar
Default No...
No a full size will not fit . The spare tire well is not deep enough. the cover board will be sitting up in the air if you do this.
Old Dec 15, 2004 | 05:12 PM
clue1279's Avatar
im pretty sure i saw a full size spare in the back when i went to go see the car at the dealers
Old Dec 15, 2004 | 05:22 PM
iowagary's Avatar
The doughnuts are significantly thinner. But there is a little tray full of tools that sits on top of the doughnut. I think it might be possible to fit a 17" in, but you might need to go to a thinner wheel and tire to do it. I don't think you could fit a 215/45-17 in there, but maybe something like a 195/65-17 or something.
Old Dec 15, 2004 | 05:29 PM
JasonH's Avatar
A stock wheel and tire will not fit properly in the back. It will sit in the well where the temporary spare goes, but you will not be able to re-fit the cover because the wheel sits up too high. I know this from experience as I had a flat, used the spare and put the flat tire in the back. It's probably a good 4-5 inches too tall.
Old Dec 15, 2004 | 05:41 PM
iowagary's Avatar
Also, if it would fit, the manual would tell us that. Instead they provide us with a special strap and tie down system. In the event of a flat, you're supposed to put your tire in the trunk on top of the cover and use that special strap system to secure it so it doesn't end up flying through your window or something.
Old Dec 15, 2004 | 07:33 PM
sheep's Avatar
Yeah, the spare unfortunately is a doughnut but you saved all the money on the price of the car by getting it that way. Still wish I had a full-size on though.
Old Dec 15, 2004 | 07:42 PM
iowagary's Avatar
Part of me wishes it was full size. The other part of me is glad it's small. I have gotten a flat once in my life, so I don't plan on using it much, and I'd rather save the money, space, and weight by having the doughnut.
Old Apr 7, 2005 | 09:53 PM
shafted's Avatar
Hrmmms that's really bad, it's a shame that Toyota didn't make it large enough to fit the full size spare... I'm sure there is a way around it though
- Mister S -
Old Apr 8, 2005 | 01:26 AM
GT4Dreams's Avatar
There is no way around, the thing is more yellow than my pee!
Old Apr 8, 2005 | 01:31 AM
scoobyroo2002's Avatar
yeah GROSS!! only use it to SPEED to the nearest tire shop
Old Apr 8, 2005 | 03:48 AM
Shadow_tC's Avatar
Haha! Seriously!
- Desirée
Old Apr 8, 2005 | 04:05 AM
rjj130's Avatar
Yeah a full size definitely will not fit...that's why they give you the tie downs for if you get a flat. It's in the manual!!
Old Apr 8, 2005 | 05:20 AM
I would rather tie down that spare with some cement blocks and throw it to the bottom of a lake why did they have to come out with such a nasty colored spare! i think i am going to paint mine black just in case HE HE!
Old Apr 8, 2005 | 05:39 AM
Somnambulated's Avatar
Great idea... Except if you speed on a doughnut, you'll probably melt the glue holding the rubber doughnut 'tire' to the hub.
Old Apr 8, 2005 | 06:10 AM
DANG IT! AHH!! thats where there is duct tape! LETS DUCT TAKE THAT PUPPY BACK TOGETHER! AH HE HE
Old Apr 8, 2005 | 02:36 PM
scion_tC's Avatar
this car does come with tire pressue sensors, so that explains the spare
Old Apr 8, 2005 | 03:03 PM
JasonH's Avatar
I don't really know what you're saying here (what explains what about the spare?) but the car does not have tire pressure sensors. It uses the ABS sensors to measure the revolutions of each wheel and if one is different it knows that tire has lost enough air to reduce its overall diameter, then it turns on the warning light.
Old Apr 8, 2005 | 04:06 PM
Stinky_Wizzleteats's Avatar
Hahahaha! I know, when I pulled it out to check the air for the first time I was shocked, disgusted, whatever all at the same time. I thought I was the only one who had that yellow hub.
Old Apr 8, 2005 | 04:11 PM
Darkness's Avatar
I hate the spare tire, like...unlike other cars where it's just plain black, ours has to be the ugliest color! freakin peach...
