WHAT TO ADD BEFOR A TURBO
Old Aug 22, 2008 | 02:10 AM
Jrellzgottem's Avatar
Default WHAT TO ADD BEFOR A TURBO
Looking for some advice on what to add before putting a turbo on my 06 scion tc.
also im looking for quick take off , any advice? thanks
Old Aug 22, 2008 | 02:19 AM
crush02342002's Avatar
gauges are a nice start.......gives you something to do while waiting for the arrival of your new toy....lol
Old Aug 22, 2008 | 02:25 AM
olaHalo's Avatar
upgrade the clutch
that way you can break it in without that addicting turbo in the way
Old Aug 22, 2008 | 02:27 AM
good point olahalo
Old Aug 22, 2008 | 02:41 AM
Ace83's Avatar
Ronin Scion
if you want a quick take off, fast boost response and more power on the bottom side, get a flywheel together with an upgraded clutch, get a small turbo like a gt28, lsd if you want to spend on it..
Old Aug 22, 2008 | 02:47 AM
Already added cold air intake, JVT racing header, front sway bar, raceing downpipe, and JVT Exhaust, witch i could feel somewhat of a HP Gain, but nothing like i want, basically looking for, if someone wanted to race on the streetz, ill smokem, ill post some pics of what i have, thanks for the tips as well.
Old Aug 22, 2008 | 02:52 AM
huslindan's Avatar
dude i dont have a turbo but i no some stuff u minus well take off ur header your intake and ur downpipe cuz u cant use any of that with a turbo set up... u just wasted that money ur best bet is to so supercharger if u want to keep that stuff on
Old Aug 22, 2008 | 02:53 AM
Ace83's Avatar
Ronin Scion
the most of the upgrades you have will be taken off when you put the turbo, i say go for gt28, its enough to get you close to 300 on low boost and it will be a fun quick spooler.. but dont go racing on street, you get somebody killed
Old Aug 22, 2008 | 02:57 AM
o well of course i cant use what i have on a turbo set up, yeah i wasted some money on the downpipe and header, but i could sell it cheap to someone around here, its hard getting auto parts sent to germany. but yeah thanks ace83 ill look into that
Old Aug 22, 2008 | 06:34 AM
Mr_Meaty's Avatar
motor mounts would help get the power to the ground too...
Old Aug 22, 2008 | 12:12 PM
B_Real45's Avatar
Although that's not a neccessity...
I would do as Ace suggested and pick any GT28. There are several to choose from.
You can go to ATPturbo.com and pick up their cast T25 manifold and a downpipe for internally gated setup.. because most GT28's are internally gated.
Keep your IC piping small - around 2.0" for the hot side and at the most 2.5" on the cold side... although for low hp and quick spool I would do 2.25".
Old Aug 22, 2008 | 01:39 PM
paul_dezod's Avatar
Scionetics
KAD
I would recommend starting with a clutch if your considering FI. Most of them require a 500-700 mile break in period anyway. So might was well get that done. Then maybe an exhaust...
Old Aug 22, 2008 | 02:21 PM
Ace83's Avatar
Ronin Scion
yeah priority IMO, considering you have good complete kit w/ necessary F/I accessories
1. clutch
2. exhaust
3. suspension stuff like swaybar, endlinks, coilovers/good spring shock combo, motormounts
Old Aug 22, 2008 | 03:21 PM
paulky_2000's Avatar
How about some clutch reccomendations, folks? I think I may need to go with a better clutch-pressure plate combo....
Old Aug 22, 2008 | 03:23 PM
Of course...not till I FRY the stock combo!!! LOL!!
Old Aug 22, 2008 | 03:25 PM
Ace83's Avatar
Ronin Scion
stage 3 will do and hold good unless you go beyond 350 tq
Old Aug 22, 2008 | 03:28 PM
paul_dezod's Avatar
Scionetics
KAD
I'd recommend STage 4 over the 3, but it depends on the power that you're gonna make.
Old Aug 22, 2008 | 03:37 PM
Any peticular brands? Something streetable and not overly grabby, I'd think. Heavy pedal not a big issue.
Old Aug 22, 2008 | 03:40 PM
Ace83's Avatar
Ronin Scion
competition, being not too grabby is what you like go for stage 3.. but my stage 4 isnt that bad not even heavy on the pedal, just a lil bit stiffer than stock but i have a clutchmasters
Old Aug 22, 2008 | 03:43 PM
paul_dezod's Avatar
Scionetics
KAD
Competition Clutch Stage 4 is the one of choice by about 90% of our turbo customers. In stock as well.
http://www.dezod.com/pd_competition_...e_4_clutch.cfm
