Head unit/Electric Mirror Problem. Fast Help Appreciated.
Old Aug 28, 2008 | 06:51 PM
SiKoTiC's Avatar
Default Head unit/Electric Mirror Problem. Fast Help Appreciated.
Was workin on my tC like last week and my subs were not playing, everything looked fine, i was in the back of my car and then my whole headunit just turned off. (stock radio 2008 tC) and lost power.. I cant even turn in on anymore and now my electric mirror buttons on my switch pannel arent working.
Cant tell if this is a fuse, or whatever but if anyone can help me it would be much appreciated.. im really not sure how it happend i was not touching anything at the time the deck turned off.. so ___ without music :/
Old Aug 28, 2008 | 07:00 PM
mattieg's Avatar
Possibly is a fuse. The panel is under the steering column towards the door. Pop your head under there and pull the cover off. Should be a 10 or 15 amp fuse.
Old Aug 28, 2008 | 07:04 PM
equinox2355's Avatar
I agree its probably a fuse, if you have a fuse tester use that, sometimes a fuse can look fine but not work. You are somewhat local, you might want to goto one of the meets (Thursday there are meets in concord if I recall correctly)
Old Aug 28, 2008 | 07:32 PM
tri856's Avatar
its prob a fuse
Old Aug 28, 2008 | 07:44 PM
SiKoTiC's Avatar
fashoo thanks alot guys ima go check that out. im really hoping this works.. Where can i pickup on some fuses? radioshack?
Thanks alot guys ill be seein you at some meets shortly
any car parts store should have them.
Old Aug 29, 2008 | 05:05 AM
mattieg's Avatar
Ya pennies for fuses... you should have some spares in the actual fuse box. Equinox you have no idea how many times at work i see fuses that look fine but are shorted out. Its like a hairline fracture on the fuse and it stops working!
Old Aug 29, 2008 | 02:36 PM
STNC's Avatar
tiny fuses!
Mini-Blade I think
Old Aug 29, 2008 | 04:31 PM
mattieg's Avatar
I thought they were the new low profile ones
Old Aug 29, 2008 | 04:44 PM
Yep I have seen the hairline fractures too, thats why I recommended a tester and they aren't that much usually, ive seen fuses and a tester for under $20.
Old Aug 29, 2008 | 04:47 PM
STNC's Avatar
they are low pro, I wasn't being technical, sorry for the confusion, they are just really tiny
Old Aug 29, 2008 | 04:49 PM
rosedaleny806's Avatar
its the ACC fuse under by the pedals
Old Aug 30, 2008 | 05:12 AM
mattieg's Avatar
i dont know if i like the low pro fuses or not... too tiny for me
Old Aug 30, 2008 | 11:46 PM
STNC's Avatar
I don't, after the fiasco I went through.
I installed new tail lights and blew a fuse, so I went to autozone to get a new one....They told me that a mini-fuse had blown, and melted into the fuse box....Almost had a panic attack...
Luckily both Autozone and I now know what Lo-Pro's are, and back then, they didn't carry them, and now they do!
Yay!
I think they are cool looking
idriveanxa
Mar 8, 2015 12:03 PM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
