removing rear springs
Old Aug 29, 2008 | 09:49 PM
aye87's Avatar
Default removing rear springs
can you just jack up the car, and compress the rear springs with springs compressor then pull it out? or do you need to unbolt the shocks too? i dont think it need to unbolt the shock but i dont know
thank you
Old Aug 29, 2008 | 10:48 PM
jct's Avatar
jct
unbolt the bottom nuts on the shocks to get the springs out of there its a simple 10 minute or less job
Old Aug 30, 2008 | 07:21 PM
cobb's Avatar
You need to jack the rear high off the ground and support the frame, not the wheels or swing bar. You then need to remove the wheels and rear nut that holds the shocks on and slide those aside while you have a jack on the swing bar. Lower the swing bar and the springs pop out. Put the new springs in place, jack up the swing bar til you can rebolt the shocks.
Old Sep 1, 2008 | 09:24 AM
magicmanjk808's Avatar
no compressor needed. you don't even need to take off the wheels. jack the rear up. as you're jacking it up, once there is enough room under the car for you to remove the 17mm bolt at the bottom of each shock, get under there and remove it. pull the bottom of the shocks off of the support. now, keep jacking until you hear the springs fall out. install new springs and reverse the process.
Old Sep 1, 2008 | 05:03 PM
Just1n's Avatar
Wagonistas
if you have to ask this question dont work on your car. lol
JUST KIDDING lol
Old Sep 1, 2008 | 07:24 PM
aye87's Avatar
so it wont work without unbolting the shock bolt
Old Sep 2, 2008 | 01:34 AM
jct's Avatar
jct
nope
Old Sep 3, 2008 | 03:29 AM
cobb's Avatar
The rear bar that holds the wheels needs to swing out enough for you to remove them.
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
kleecker
Jan 9, 2015 02:26 PM
lunchbx05
Dec 29, 2014 07:53 PM
fluxingnation
Dec 26, 2014 04:28 PM
deathcabforme
Oct 29, 2003 05:23 AM
