Water Lines GT3076R
Old Aug 31, 2008 | 06:00 PM
Boi's Avatar
Boi
Default Water Lines GT3076R
almost done with my new setup, never had a watercooled turbo before so i dont know where to run the lines. any suggesttions? pics would be great.
Old Aug 31, 2008 | 06:46 PM
deathbyc4's Avatar
off the throttle body, search next time.
Old Aug 31, 2008 | 07:37 PM
coryjames's Avatar
tap one line into the feed to the throttle body the other to the return got to love the 3076 my turbo spools for like 30 seconds when i get out my car from all the heat exiting the manifold lol its sick
Old Aug 31, 2008 | 08:24 PM
aen's Avatar
aen
right on the throttle body there are two lines, they are right off the front of hte throttle body, one is a feed, one is a return line...you have a decision, you can take it off of the throttle body and just use that or you can tap them.
i took them off.
Old Aug 31, 2008 | 08:39 PM
coryjames's Avatar
did u eliminate them from the body aen? i wanted to but in colorado your throttle body will stick kinda sucks
Old Aug 31, 2008 | 09:48 PM
aen's Avatar
aen
i did it for sombody else's car, but she lives in vegas so it's not like it's going to stick freeze
Old Sep 1, 2008 | 01:47 PM
Ace83's Avatar
Ronin Scion
An ideal way of doing the watercooled setup is to clock the turbo in a way that one of the water inlet on the turbo is higher than the other, that way when the car is turned off, water on lower water line makes its way to the hot turbo and then it boils and exits the higher port, it also minimize air pocket from settling on the turbo water chamber.. mine is almost vertical or level, it should work still, i could even hear boiling water on the turbo area when the car is off
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gqdabien
Oct 8, 2015 05:36 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Btp907
Sep 11, 2015 11:46 PM
gottoaster
Sep 6, 2015 07:17 PM
