Does anyone know why our engine bay gets so hot?
Old Sep 4, 2008 | 02:50 PM
FromTheOld's Avatar
Default Does anyone know why our engine bay gets so hot?
EDIT: I already got my answer guys, there's no need to respond anymore. Thanks to all who gave me actual answers.
Old Sep 4, 2008 | 02:53 PM
ack154's Avatar
It's cause the engine is in there!
My guess is that it's b/c the exhaust comes out the front and the heat doesn't always dissipate through the bottom of the engine bay.
Old Sep 5, 2008 | 12:05 PM
AAG's Avatar
AAG
DeepSouth Scions
Is it over heating? How did you determine it's running so "hot". All cars run hot because that's what there operating temperature should be at.
Unless your needle is past the half way mark I wouldn't worry too much. Just make sure the coolant is full and you don't have debris blocking the upper or lower grilles. If you're still worried, buy some washers and extended bolts and lift the rear of the hood to let some of the heat out.
Old Sep 5, 2008 | 03:37 PM
Black_Sheep_xB's Avatar
its a fine line for manufacturers.. hotter equals better MPG's, but less performance.. in todays market MPG's wins...
Old Sep 5, 2008 | 03:42 PM
draxcaliber's Avatar
wow...that is am amazingly stupid question...and the thing is, they really don't get that hot. go stand next to my bro's mercedes cls550 and see how much heat that thing puts out while idling.
engines get hot because all they do is explode gas and air over and over again, so they get hot quickly, they are supposed to get hot, but not too hot, that is what the radiator is for.
Old Sep 5, 2008 | 04:48 PM
ShaffNasty's Avatar
^ wow... The guys asks a simple question and you insult him... classy! and your bros mercedes will kick off more heat cuz it is a bigger engine (v8?)...
Old Sep 5, 2008 | 07:32 PM
FromTheOld's Avatar
Thanks a-hole, that is "am" amazingly useless response. Compared to my other car's engine, it's very hot or at least it SEEMS very hot compared to it. It wasn't something retarded like "why isn't it as cold as a refrigerator". I know this is a public topic, but could you consider not responding to this thread anymore? I don't need anymore useless garbage from you.
Old Sep 5, 2008 | 08:21 PM
BBN-Boys's Avatar
Cool down guys. No pun intended….
That's a very good question. I noticed that too. After placing my hand on the hood after a nice ride, the hood gets really hot. If you ever been under the car, all those plastic engine covers underneath don't help with releasing the heat or bringing cold air in either.
Old Sep 5, 2008 | 08:48 PM
ShaffNasty's Avatar
Ya the engine bay is pretty sealed up... I heard about this thing called the "ZIO mod" and he says it works AMAZING...
Old Sep 5, 2008 | 09:55 PM
jthistle's Avatar
The engine does not get too hot. I have a ScanGaugeII and it reads my coolant temp as 190 F during normal driving.
Old Sep 5, 2008 | 09:56 PM
Big_Bird's Avatar
It's because scion owners are so sexy
Old Sep 5, 2008 | 10:00 PM
qbano239's Avatar
most engines with exhaust coming out of the front get real hot. both my tc and my integra get super hot
Old Sep 5, 2008 | 10:13 PM
BBN-Boys's Avatar
BEST reason so far!!!! Totally true.
Old Sep 6, 2008 | 02:57 AM
hey i turned on a light, and i noticed that it too got hot! and then turned on the stove, and it got hot, and then i boiled some water, and it as hot too, does anybody notice this?
ask a stupid question, get an appropriate answer. i'm pretty sure there are little warning stickers under your hood telling you not to touch things that get hot. it is supposed.
Old Sep 6, 2008 | 03:02 AM
kikcaffine's Avatar
Hey spanky, I bet its exactly the same temperature if not actually colder than what ever your other car is. Truth to the matter is Toyota engines typically run cold. Where most domestic cars run at about 210degrees, the tC is at 180. I feel that I should tell you though, if you feed your engine ice cream it will stay cold and happy.
Metro273's Avatar
That's what I like about you Drax, you tell 'em straight up! No BS...
Old Sep 6, 2008 | 04:45 AM
FromTheOld's Avatar
I already got my answer many posts ago from the guy with the Scan Gauge. You guys really don't need to reply anymore unless you're just attempting to make yourself feel better by insulting me.
Old Sep 6, 2008 | 04:00 PM
coryjames's Avatar
Default Re: Does anyone know why our engine bay gets so hot?
Is there any specific reason why? Is the cooling system sufficient enough, or does it need help, like the use of a radiator block-off plate?
lol i have alot more heat being generated in my bay then most huge manifold huge turbo a intercooler blocking radiator all that great kinda stuff my water tems never get over 210 with the ac on thats at a long stop say 30 mins with the car running my intake temps have seen 250 a few times second i start driving again it gets fine want to know a tip to keep it a little cooler open the hood take out the weather strip on the back give the air some where to go it will help alot
Old Sep 6, 2008 | 10:17 PM
xseveredveganx's Avatar
Utah Scions
^^^old school hot rod tip right there.
carid
Mar 30, 2015 07:08 AM
Halo19boy
Jan 27, 2015 10:19 PM
eric_m
79
Mar 17, 2013 12:21 AM
Docsnuff
Jul 9, 2010 02:52 AM
