paint for Taillights
Old Sep 5, 2008 | 03:51 AM
Amaran06's Avatar
Default paint for Taillights
where is the best place to buy some paint to smoke my taillights??
Old Sep 5, 2008 | 03:52 AM
xseveredveganx's Avatar
Utah Scions
You can get the VHT Niteshades via the eBay. Quite a few people have used it.
bigducexd's Avatar
up ur moms booty whole!! haha jkjkjk bro
Old Sep 5, 2008 | 09:40 AM
hwybox's Avatar
jegs.com sell it to, cheap. VHT niteshades
Old Jan 28, 2009 | 02:26 AM
anthonyha's Avatar
when you tint the tail lights do you have to sand them down or no?
Old Jan 28, 2009 | 03:18 AM
bigducexd's Avatar
nope just make sure u clean them good
Old Jan 28, 2009 | 04:09 AM
Jtc's Avatar
Jtc
Here is a good guide to tinting a tc's taillight but it's the same process for any light. Just make sure to use some kind of clearcoat cause otherwise the VHT will come off in about a month. The Duplicolor stuff from Advance auto works well if you can't get the stuff he uses.
Old Jan 28, 2009 | 04:59 AM
SiZzOuRcE's Avatar
This is what I did for mine and for the rest of the Scikotics Ft. Lauderdale chapter:
1. Sand light with 2000 grit sand paper
2. Clean very very thoroughly with soap and water
3. Remove any access dust or moist areas
4. Spray on VHT or other (**see below**)
5. Depending on how dark you want it, you may need to spray it more than once over and in that case wait at least 20 mins between coats if not longer
6. Let the paint cure overnight or for at least 4-5 hours
7. Clean thoroughly once again
8. Sand with 2000 grit again
9. Spray clear coat using the same rules as the tint spray
**There is a product on eBay called Vans. It is similar to VHT Niteshades, but it comes out ALOT cleaner, clearer and shinier. If you use this, clear coat may not be necessary.
Another option is to go to your local paint shop, have them mix up a batch of clearcoat and black paint and spray the lights. Not sure what the ratio would be as I have never done this method before.
Let me know how it works out for ya.
Old Jan 28, 2009 | 05:01 AM
SiZzOuRcE's Avatar
Old Jan 28, 2009 | 03:40 PM
cobb's Avatar
Wow, wouldnt be cool to have lamps that match your body color?
Old Jan 28, 2009 | 03:43 PM
cobb's Avatar
I found your moms panty hose works well too for tinting lenses.
http://www.team-integra.net/forum/di...PagePosition=1
Old Jan 28, 2009 | 03:51 PM
SiZzOuRcE's Avatar
I have no comment for that DIY . . . yes I do . . . ONLY A HONDA OWNER WOULD DO THAT!!!!
Old Jan 29, 2009 | 12:10 AM
Utah Scions
http://www.jonstintedtails.com/galle...picture&id=273
It's definitely doable.
And so people know, it's not the actual clear coat you would want to mix with body color, or black, for that matter. Most (if not all) clear coats are catalyzed. Auto paint stores have a clear base, not a clear coat. You can mix the clear base with the black or body color, whatever.
Working for a custom shop for a few years has had it's perks. :D
jeremydoc
Sep 16, 2015 11:31 PM
Btp907
Sep 11, 2015 11:46 PM
yoson13
Scion xA Aero & Exterior
Aug 30, 2015 07:38 PM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
