A/C Idle Vibration
Old Sep 10, 2008 | 07:36 AM
lasrx's Avatar
Default A/C Idle Vibration
How much engine vibration is normal when idling with the AC on? Right now if I'm at a full stop at a light and the A/C is on and the transmission is in Drive the engine/supercharger makes quite a bit of noise and I can see the windshield wipers vibrate. Vibration goes away when shifted to Neutral and noise + vibration goes away in Neutral /w A/C off.
Old Sep 10, 2008 | 07:55 AM
TylerC08's Avatar
If you're under warranty just let the dealer have a look at it.
Otherwise, others have had similar issues b/c of mounts, a/c belt tensioners, blower motor, etc.
Old Sep 10, 2008 | 08:10 AM
lasrx's Avatar
Just passed into the 36k range a few weeks ago. I hope this isn't something that is only covered under the basic warranty.
Old Sep 10, 2008 | 08:29 AM
B_tC's Avatar
i have this problem too. that's funny cuz i'm around 36k myself.
Old Sep 10, 2008 | 09:05 AM
TylerC08's Avatar
More than likely it would be under your drivetrain warranty which is 5 yr./60k, just take her in.
Old Sep 10, 2008 | 09:53 AM
lasrx's Avatar
Off to the dealer it is. I wish it was just some screw that needed tightening.
Old Sep 10, 2008 | 12:57 PM
B_Real45's Avatar
Watching - same issue with 34k miles.
Old Sep 10, 2008 | 01:03 PM
goingcarcrazy's Avatar
My car has had it most of its life. I chalked it up as just another noise our cars make. My Saturn did that too, as does my friend's RSX, so I never really worried about it.
Old Sep 10, 2008 | 07:10 PM
take4roll10's Avatar
my car vibrates at idle and vibrates worse when the a/c is on.
Old Sep 12, 2008 | 01:10 PM
tcengel's Avatar
I have Speedsource engine mounts and mine whole hood vibrates with the AC on. It's normal though, My MR-2 did it and my WRX did the same. It's just the compressor passing vibration through the firewall. My first suggestion is to replace or clean your cabin filter (does the TC have one?)
Old Sep 14, 2008 | 02:31 AM
06CStC's Avatar
Heh, i'm having some vibration issues myself too, but prob not as bad as yours from your description. My old Ford Probe had it so bad, it was like sitting on a massage seat while at a stop light. Turning on the a/c definitely made it worse, lol.
Old Sep 14, 2008 | 02:46 AM
kirk212's Avatar
Its a really common thing with these cars. Theres not a whole lot you can do about it. Putting in new motor mounts or bushings only makes it louder. I have an Ingalls ETD, and its pretty loud, espicially with the AC on.
Old Sep 14, 2008 | 03:44 AM
TCFROEZEL's Avatar
mine began vibrating more now i am @ 36K ...
Old Sep 14, 2008 | 07:32 PM
paulky_2000's Avatar
Until mine quits working...I'm not going to worry, as most people report vibration w/ the air conditioning engaged.
Old Sep 14, 2008 | 09:46 PM
arbnpx's Avatar
Mine does it too, but I've shrugged it off as probably being caused by extra resonance when the engine is under the extra load of the compressor.
Old Sep 14, 2008 | 09:54 PM
Higgy's Avatar
Mine started it last night when i was at mcdonalds. I had the sunroof open and turned the ac on and the sunroof started rattling. If i held onto the sunroof it stopped. weird, ill see if i can reproduce it next time im in the car.
Old Sep 14, 2008 | 10:15 PM
Let me get this straight...
You had the a/c on AND the sunroof open???
WHY?
Old Sep 14, 2008 | 10:18 PM
jct's Avatar
jct
heh its the same way why ppl have the a/c cranked up on max a/c with all the windows down
Old Sep 14, 2008 | 10:19 PM
Higgy's Avatar
Well I was DDing and i had the windows down seeing as how it was a cool night. go to the drive thru and my way drunk friend was getting hot since we werent moving. So i said "oh no, better turn the ac on real quick to get some cool air in here before he pukes." so i turned it on and he ended up running out the car and puking. then i noticed the rattle and investigated the soruce.
Old Sep 14, 2008 | 10:21 PM
kirk212's Avatar
nice way to put it ^^^^^^^
