HELP PLEASE!!! NST Underdrive kit!
I need a little help here…
I bought the entire kit from Non Stop Tuning pulley kit for a Scion xB 08. The underdrive crank pulley and the alternator & water pump kit.
But I spent a lot of time searching on the forum the correct belt # that I need. I found a lot of belt numbers, and I really confused. Inclusive on the website of NTS have different belt # if we compare on the forum.
Anyone that have the same setup on a Scion xB 08, that can share the correct belt # that use?
Please share the correct belt # PLEEAAASEEEEEE!!!!
I need to know if the belt K060735 its the ideal belt for a complete NTS underdrive crank pulley and the alternator & water pump kit set, because I can't find it on a local auto parts shop and I need to order...
Thanks a lot!!!
Thanks a lot!!!
If the Scion xB2 use the same engine 2AZ-FE as tC, why are a variety of # belts that fit different scions tc and xB2? Different people uses different # of belts that claims that belt fits great in their car? I’m confused about that.
Example, if the 2AZ-FE it’s the same engine, why the05-06 tC its different of 07-08 tC belt and its different number of 08 xB?
K060735 its the ideal belt for a complete NTS underdrive crank pulley and the alternator & water pump kit set for a Scion xB 08??? This is my qquestion on this quest of beltsss....
Next time you have a question like this, please feel free to look for us on AOL Instant Messenger at the screen name "NSTonAIM" or give us a call M-F at 281-917-0221.
As listed on our website, the 2nd gen xB owners should use K060735...
http://www.nonstoptuning.com/infoPageBelts.htm
Here is a very good place to order this belt from...
http://www.rockauto.com/catalog/raframecatalog.php
click on PART NUMBER SEARCH and put in K060735
The belt numbers listed on our website have been tested, and show to fit perfectly, for each application. We recommend Gates belts which can be ordered from your local auto parts stores such as PepBoys, Napa, AutoZone, Oreilly, Advanced, etc. You can also order these belts from many online parts stores, such as the above link.
Finally, while several cars use the 2AZFE, not all use the same exact accessories. Some use different alternators, some use different belt tensioners, etc. Therefore, some use different belts. We have tried to make things very simple for everyone by listing an up-to-date, and accurate, belt guide on our website.
When in doubt, it may be a good idea to go to the source, rather than run around asking others who may have no clue ;)
Good luck and have fun with all your projects everyone!!!
NST is www.NonStopTuning.com
http://www.nonstoptuning.com/pKitToySciXB.htm
ColonelSanders85
Dec 9, 2020 09:44 AM
NonStopTuning
Jun 29, 2015 07:42 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
