Install Quote
Old Sep 17, 2008 | 02:06 AM
dave2610's Avatar
Default Install Quote
So this is the quote i got from a local shop to install my dezod kit seems high to me what do you think.
Labor Hours Rate Amount
R & R EXHAUST MANIFOLD OR GSKT (ONE) 1.50 $100.00 $150.00
R & R OIL PAN OR GASKET 3.10 $100.00 $310.00
Install FMIC 5.00 $100.00 $500.00
R & R FUEL INJECTOR 2.40 $100.00 $240.00
Install oil Temp Gauge 1.50 $100.00 $150.00
Install Wideband Gauge 2.00 $100.00 $200.00
Install Boost Gauge $100.00 $0.00
R & R FUEL PUMP 2.10 $100.00 $210.00
tuning 5.00 $100.00 $500.00
R & R AIR CLEANER ELEMENT 0.15 $100.00 $15.00
Install Vacuum Manifold 0.50 $100.00 $50.00
Install Turbo Oil Feed Line 0.50 $100.00 $50.00
$2,375.00
Part No. Parts Quantity Each
VIBVM Vibrant Vacuum Manifold 1.00 $37.49 $37.49
Walbro 255lph Pump 1.00 $120.00 $120.00
Misc Shop Supplies (Brake Klean, Vacuum Line Etc.) 1.00 $40.00 $40.00
$197.49
Subtotal $2,572.49
Tax $0.00
Total $2,572.49
Old Sep 17, 2008 | 02:15 AM
STNC's Avatar
Pricey!
Idk how much a normal install runs though...
Old Sep 17, 2008 | 02:16 AM
B_Real45's Avatar
Do it yourself with someone who is more experienced than you. It'll save you money and you might learn a thing or two.
Old Sep 17, 2008 | 02:19 AM
dave2610's Avatar
that is an option but dont want to drive around untunned
Old Sep 17, 2008 | 02:20 AM
STNC's Avatar
drive straight to a tune place after the install? idk
Old Sep 17, 2008 | 02:24 AM
dave2610's Avatar
that would be the best case scenario but not likley
Old Sep 17, 2008 | 02:26 AM
SVicksTC's Avatar
ya install that ish yourself....Good saturday project.....Many Trips to Lowes/autozone haha
Old Sep 17, 2008 | 04:34 AM
thendawg's Avatar
haha you can say that again, i built my own kit and i wish i wouldve kept all the autozone, orielleys, and home depot reciepts lol gah wish i cudve just known everything i would need and bought it all at once Best part was when i was in the MIDDLE of making my downpipe and i ran out of mig wire, at 12am that sucked, o well i think i did pretty good building my own kit and fully installed in 2 days
Old Sep 17, 2008 | 04:38 AM
thendawg's Avatar
so yea from my experience i think anyone even slightly mechanically inclined could install a kit themselves, i dont have a TON of f/i experience but i didnt have a prob fabbing my own kit let alone just installing it, find someone thats slightly mechanically inclined and get to work! Its really a lot of fun As for the tune, im sure dezod will send you a fic basemap, or just create a basemap that subtracts for the side of your injectors, set everything you dont want to use to percent and zero out the maps. than youll be running like stock, just dont go into boost and youll be fine, i get practice of staying out of boost between pay days when i cant afford gas, its not that hard if you watch your boost guage
Old Sep 17, 2008 | 08:45 AM
aen's Avatar
aen
wow they are really ripping you off.
at MOST it should cost 600 to install. hell the dealership installs supercharger for 600.
you should do it yourself, can you work a 13mm, 11mm, 10mm and 12mm wrench? if you can you can do it.
only hard part is the oil pan and we all have tricks.
mine involves a bunch of small box cutter blades and a mallet, others involve torch and screwdrivers.
Old Sep 17, 2008 | 10:59 AM
SoFloTC's Avatar
thats alot.. japtrix quoted me 1200 for full install.
Old Sep 17, 2008 | 01:25 PM
paul_dezod's Avatar
Scionetics
KAD
Fresh off of our install manual courtesy of Joe.
That is insanely expensive. Time to look somewhere else or do it yourself.
Old Sep 17, 2008 | 07:22 PM
aen's Avatar
aen
great minds think alike paul.
Old Sep 17, 2008 | 07:26 PM
CarbonXe's Avatar
Rofl, $100 per hour for labor. Where the hell are you going, a BMW dealer?
Also, I stopped reading after I saw that they want $150 just for R&R on the manifold. That's at most a 20 minute job.
OMG. $500 to install the F/IC? WTF?! If that's not including the PnP, then just buy the PnP for $300 and do it yourself. Remove glove box, unplug harness, plug in harness, use some strong double sided tape and stick to the top of the stock ECU. Done. 10 minutes.
Old Sep 17, 2008 | 07:29 PM
coryjames's Avatar
it took me 4 hours with my gf to put on my kit
Old Sep 17, 2008 | 07:35 PM
a_german_named_hans's Avatar
thats a retarded amount of $$
Old Sep 17, 2008 | 07:44 PM
svencarlson07's Avatar
thats very expensive..i had mine installed for 800 bux and tuned for 350 so was a total 1150 installed and dyno tuned
Old Sep 17, 2008 | 07:46 PM
nodsetse's Avatar
While I agree it's too much, that's the rate my local Toyota/Scion dealer charges too.
Old Sep 17, 2008 | 07:51 PM
brett561tc's Avatar
2.4 hours to remove and replace fuel injectors??? WTF?!!!! im surprised that he left out 3 hours to bleed and replace blinker fluid, 5 hours to high speed balance the intake manifold, and 1 hour of cleaning your back off with a towel, after he pulls out and blows his load.
please find a local forum, and spread the word about this shop.
Old Sep 17, 2008 | 08:11 PM
dave2610's Avatar
i figured it was high crappy part is there the only shop in the area
looks like im gonna do it
