weather tech visor help? please
Old Oct 2, 2008 | 02:09 AM
lakaikills's Avatar
Default weather tech visor help? please
so they came in today... well i was trying to instal them and i cant get the stupid window to go up. it looks like it get stuck where you put that first wedge or whatever its called. its super irratating cause i know how easy it is.
anybody encounter this problem?
Old Oct 2, 2008 | 06:38 AM
Hyghgynx's Avatar
You have to fiddle with the visor. It took me a couple of tries before it worked with me.
Most important rule; BE PATIENT!!
Old Oct 2, 2008 | 01:02 PM
ExpresScion's Avatar
Yeah, when you first install them, the channel isn't wide enough for the window and the visor. Over time, it will stretch and your window will close like normal.
Old Oct 2, 2008 | 02:09 PM
lakaikills's Avatar
thanks guys. im going to try it after work today. hopefully get them to work fine.
Old Oct 2, 2008 | 02:19 PM
rosedaleny806's Avatar
i had the same problem when i installed my inchannels its normal if ur window doesnt go up easily it takes awhile to settle in u jus have to go bak in forth with the window and if u can leave the window closed so it settles better
Old Oct 3, 2008 | 12:13 AM
SengTC3's Avatar
Are there any other brands other than weathertech?
Old Oct 3, 2008 | 01:09 PM
^ yeah i have AVS in channels
Old Oct 3, 2008 | 01:13 PM
ScionJim23's Avatar
I had the same issue with mine. pain in the butt. window does not close right at all. ended up selling mine to a friend cause the window looked all weird.
Old Oct 3, 2008 | 01:29 PM
lakaikills's Avatar
well i got my windows partially all the way up, but still a little crack im hoping that through time it works perfectly but we'll see.
Old Oct 3, 2008 | 01:52 PM
u jus have to close and open back and forth till it closes all the way shut. its normal for it to happen the longer u have it in the more it setrles after awhile it will go up with no problem with the automatic windows but to close it for now jus go bak and forth
Old Oct 3, 2008 | 01:53 PM
lakaikills's Avatar
thanks i think it'll settle in for sure.
Old Oct 3, 2008 | 01:56 PM
yeah it jus takes patience and its a pain at first but once its good it look awesome
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Jus2tastee
Oct 1, 2015 08:57 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
