New Product Announcement: The WOT Box - Discounted Group Buy
Hello everyone! I would like to introduce our company, N2MB Racing. We make electronics for performance cars. Our base is in the SRT-4 community and you can check us out over on SRTForums here: N2MB Racing - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
We have decided to branch out into new vehicle communities and bring our popular WOT Box product to the Scion tC and other Scion cars.
The WOT Box adds two major features to any car. They are No-lift shifting and 2-step launch control.
The No-Lift Shift feature makes no-lift shifting easy by cutting your engine's ignition for a very short period while you no-lift shift. No-lift shifting is keeping the gas down through the shifft. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T.
The major benefits are:
-Lower ETs
-Reduced chance of missing a gear
-More consistent, effortless shifts
-Reduced wear on the transmission
-Reduced chance of major transmission damage
The 2-Step Launch Control modulates the ignition by dropping power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost! If your car is naturally aspirated, it will still help you have more consistent launches.
You can read more about the WOT Box on our website at:
http://www.n2mb.com/wotbox
You can view Scion tC specific installation instructions here:
http://www.n2mb.com/sciontcinstallationinstructions
Thank you to NVMyTc for doing the test installation and the write-up.
As an introduction, we will be running a group buy for ScionLife Forum Members for the rest of October. You will receive a $10 discount and the privilege of being one of the first tC's with no-lift shifting and launch control. To check out at the group buy price, visit this website:
http://www.n2mb.com/wotboxgroupbuy
Thanks, and let me know if you have any questions.
Reviews:
Originally Posted by UNiT_xEr0
THAT THING IS INSANE!!! he took me for a spin and wow!! i'm for sure gonna pick that up. stays in boost when you shift. its amazing
Originally Posted by NVMyTc
Originally Posted by unxpectederror
i cant wait
also would this be beneficial to the guys with s/c's because i know they build boost differently?
It will help you get your launch a little more consistant, but most of all it will cut down your time between shifting. You also stay in boost while shifting threw the gears
I use to think I could shift fast, but I cant even compare it to a WOT shift.
I have a good amount of people going to the track today with me, I should be able to get some good videos
So I went to the track today as soon as it opened and I was only able to get 5 runs in. Since it was my first time at the track with the WOT box I was adjusting it every race.
The track conditions were pretty bad and it was 97*, not the best weather for racing
I had the 2-step set at 2400 RPMS, which worked amazing on the streets but was much too low for the track.
First run was 9.596, 2-step set at 2400 RPMS, bogged on the launch bad, turbo took forever to spool
Second run was 9.272 (my 2nd fastest ever), 2-step set at 2800 RPMS, Tires spun a little but was a pretty mice launch
Third run was 9.318, 2-step set at 2800 RPMS, car hooked well w/o any tire spin but caused the engine to bog a bit
Fourth run was 9.289, 2 step set at 3000 RPMS, Car hooked pretty damn good, spun a bit but was a good run
Fifth run 9.436, 2-step set at 3200 RPMS, had pretty bad wheel hop and was slow into third gear
Right when the weather started to cool down, a guy got in a real bad crash and the races were stopped for 45 minutes while it was cleaned up, so I just watched he rest of the night. WHen I ran my personal best (9.250) I did it in 70* weather. I came damn close to breaking my personal best in 97* weather. I also didnt miss one shift tongiht, when usually i mis a shift about 2-3 runs on a track night.
My average time usually is around 9.5, so it was surprising to see how consistant I was running tonight. 3 of the 5 runs my 60' foot were 2.1XX
let me jut say, I LOVE MY WOT BOX lol
Wait till you hear the 2-step, my neighbor thought someone was shooting a gun and ran out of her house to see what was going on LOL
seems cool. but hawaii has no track so it wouldnt be too useful.. =(
also how does the no lift work? does it feel you start to engage in shifting or do you pre set it for a certain rpm?
The WOT Box wires into your clutch switch and accelerator pedal position sensor (gas pedal). When it detects that you are in WOT and then step on the clutch (no-lift shifting), it automatically engages the no-lift shift. When it sees you step on the clutch first and THEN go to WOT, it engages the 2-step launch control.
So, it is completely automatic and pretty intuitive. You don't have to enable anything or arm it. You can leave it on all the time. Just drive and it takes care of the rest for you.
so basically when im shifting i keep the clutch to the floor? im confused and noob with this..
and for the 2 step when im stopped just hold the clutch in and rev it up as if i was launching normally, correct?
and you are correct for the 2-step
No problem. You have it backwards. When you are no-lift shifting you keep your right foot on the gas through the shift and use the clutch as normal. The no-lift part is your gas foot, not the clutch foot. That allows you to hold boost through the shift, since the blow-off valve does not have to open, if the throttle does not close.
For the launch control, you hold the clutch in like normal, but then instead of revving it up normally, you floor the gas completely. It will kick in and hold the RPM you programmed, instead of hitting the rev limiter. Then you quickly let off the clutch to launch.
Originally Posted by jon_n2mb
Also, I hear that many of our customers are using them on the street for normal driving. But, we can't recommend that because our products are for closed course, track use only.
Only up to the speed limit of course
^^cool beans.
ok so how much does this thing run? and how do i adjust the rpms for the launch? what you have yours at nv?
The regular website page is here:
The user's guide to explain programming is here:
http://www.n2mb.com/wotboxusersguide
Originally Posted by Pecka13
thats awesome, sounds like the technology that the Murcielago has
http://www.n2mb.com/wotbox2
Also the new EVOs....
Our box makes it available for everyone. Some of our reviews are here:
http://www.n2mb.com/wotboxinaction
And we have videos all over youtube. Just search for N2MB and you'll see them.
before i order it... being that i am boosted how well would the 2 step work... making 310whp. i have mjor traction issues off the line thats why. sorry for all the questions but that just means i like it! hahaha
The no-lift shifting is fun all around because it allows you to stay in boost through the shift.
for the no lift i could just leave it on the auto setting or how does the adjustments on this part work? and for the 2 step i just read about it and how to make the adjustments while holding the clutch down till i reach my desired rpm! nice!
