06 tune on an 08?
Old Oct 11, 2008 | 05:07 AM
cburglb34's Avatar
Default 06 tune on an 08?
ok so as u guys all suggested i will tune my zpi ok my question is will a tune for a 06 emanage blue work on an 08 tc if i use an 08 harnes
Old Oct 11, 2008 | 06:53 AM
java09's Avatar
the tune wont work because the maf sensor change from 06 to 07-08.
Old Oct 11, 2008 | 01:33 PM
cburglb34's Avatar
thanks so much java u seem to answer all my boost problems
Old Oct 11, 2008 | 02:51 PM
Ace83's Avatar
Ronin Scion
it might work though but you shouldnt be using any tune even if its an 06 to 06,the setup specs might be different as well as some other factors.. if you use it just to run the car to drive to the tuner thats fine, if it works dont get on boost and make sure the afrs arent way off
Old Oct 11, 2008 | 03:15 PM
cburglb34's Avatar
hey ace can i drive to the tuner with out the tune i mean it is a stage zero .....and do the install there i dont want the tune to be dropping fuel when it doesnt have to so would driving with out it hooked up be better and safer i will be at 5-6 psi like stage 0 is made to do thanks in advance
Old Oct 11, 2008 | 04:45 PM
Ace83's Avatar
Ronin Scion
on a stage 0 driving to the tuner? yes you can, as stated many has been running it for months even racing with it without problems.. but you can always drive safetly be not going into boost, easy on the throttle and take time getting into speed, keep rpm not greater than 3K when shifting..
Old Oct 11, 2008 | 05:05 PM
cburglb34's Avatar
lol =[ are cars are above 3k inj fifth at all times hahahaha
alexdrummerr30
Sep 8, 2018 12:18 PM
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Gigs
Sep 15, 2015 03:54 AM
