problems since the sc install
Old Oct 15, 2008 | 09:11 PM
jonathan110987's Avatar
Default problems since the sc install
ok so i installed the sc on my 06 last weekend and took it to the dealer to reflash... well yea i drove on it without the reflash but not hard or anything... anyways my cel came on and the dealer told me before they did the reflash that i had a faulty a/f sensor and it was gonna cost 460 to change that out... i know for a fact that they are only 230 bucks cause im on my second one due to stripping the old one when i changed my header.
right now the sc is working fine but at idle (car stopped completely) it drops down to 500 and up too 1000 rpm's and its shaky and seems like its going to die.
is that the af sensor problem or something else?... i dont want to buy that part if that isnt the problem
dealer said that the af sensor was throwing that code causing the CEL...
thanks for the help in advance
Old Oct 15, 2008 | 09:15 PM
PhillyCamoBox's Avatar
u mean MAF sensor or o2 sensor or a/f guage?
Old Oct 15, 2008 | 09:18 PM
they said A/F sensor... which is on the header looks like the o2 sensor
Old Oct 15, 2008 | 09:33 PM
plmars's Avatar
I can guarantee you that dealer would not refer to it as a/f sensor. Its either o2 or MAF.
o2 sensor would not be affected by boost.
MAF could be but shouldn't be.
Did you take the o2 out of your header?
How careful were you with the MAF? These things are extremely easy to damage.
Old Oct 15, 2008 | 09:45 PM
they said that the a/f sensor was faulty when they checked why my cel was on... i did drive it without the trd tune to the dealership(30 miles)
maf i was really careful i disconnected it then took it out and moved it to the workbench inside my garge out of the way.. nothing touched it.
Old Oct 15, 2008 | 09:47 PM
CarbonXe's Avatar
There is no such thing as an A/F sensor on the tC. Take it to another dealer for a second opinion.
Old Oct 15, 2008 | 09:50 PM
the a/f sensor is the one on the header... thats what its called not the o2 sensor... trust me... i fough toyota thinking it was the o2 and they showed me in their system...
Old Oct 15, 2008 | 09:51 PM
thanks i knew it didnt make sense and i dont even own a tc lol
Old Oct 15, 2008 | 10:00 PM
http://cgi.ebay.com/ebaymotors/03-07...spagenameZWDVW
one of these.. but id get it from toyota tho... im just seeing if that is the real problem... i might just go out and switch my friends onto mine to see if it fixes the probloem before i spend 235 bucks...
Old Oct 15, 2008 | 10:08 PM
gompka's Avatar
thats your 02 sensor maybe they told you afr senor and not a/f sensor?
Old Oct 15, 2008 | 11:08 PM
ok well if i get it do yall think it will solve my idle problem?
Old Oct 16, 2008 | 01:32 AM
unxpectederror's Avatar
i say make sure its not your secondary o2 sensor first... go to autozone and have them read the code for youthey will tell you which one it is. you might just be throwing the code because of the header. you shouldn't be having problems with your primary o2 sensor yet.
it could also be your maf.. a dirty or bad maf sensor and cause a rough idle like you describe
Old Oct 16, 2008 | 01:54 AM
thanks... yea i have the defouler... ive had the header on my car for a yr with no problems...
yea its the one on the header...
Old Oct 16, 2008 | 02:02 AM
ProjectGreen's Avatar
Mine is doing that same problem with the idle. I am running the 9.5lb pulley, so that might be part of it. Later this week they are wide banding and Emanging the car, so hopefully that will take care of it.
Old Oct 16, 2008 | 04:18 AM
oh is ur cel on?
also my car also "stalls" too... it an auto...
Old Oct 16, 2008 | 04:44 AM
Mine is on because of the headers, but I have not stalled
Old Oct 16, 2008 | 06:07 AM
GhostFaceKilla's Avatar
I just had to replace my sensor today. Freaking original wire melted onto my exhaust manifold. You still interested in the gauge pod? GL on fixing your problem though.
Old Oct 16, 2008 | 04:49 PM
jetlounge's Avatar
Originally Posted by jonathan110987
oh is ur cel on?
does it stall on cold startup, and then starts up no prob? If so, this is a known (but unacknowledged by TRD) of the S/C on auto.
Get your sensor problem fixed first. You are stabbing in the dark. As someone else already mentioned, pull the code yourself to determine the issue.
Old Oct 26, 2008 | 08:19 PM
gjpjr84's Avatar
^ so it isnt just mine that has a little harder time starting when its a bit chilly outside.
the explaination i got was since it is colder the air is denser and the a/f is leaner such and such that kinda talk mess~
Old Oct 26, 2008 | 08:57 PM
thendawg's Avatar
Just for future reference for the front 02/afr sensor (wideband) heres a link to buy one for $95 It works great - its what im using in my car right now - ive gone through 2 sensors due to a turbo oil leak i had causing oil to cover the outside of the sensor
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
If the auction is closed look under the ebay seller he always has these for sale for the same price
