need to by coolant
going to go out and try to get some on monday..but was just curious if anyone knew if our coolant comes premixed...or if ill have to mix it myself...
also it was right at the low line when the car was cold...that is when im supposed to be checking right...not when its hot? if someone could clarify that would be great....
thanks
thanks
The Toyota pink coolant is good for 100,000 miles. There is no need to flush it out and replace it before then, unless you have some kind of radiator problem.
Copied and pasted this from the web:
Genuine Toyota Long Life Antifreeze Coolant, with its distinctive red appearance, provides maximum protection without the use of harmful silicates. This formula is extremely durable and because of its compatibility with non-metallic materials, it helps extend the life of water pump seals.
Genuine Toyota Long Life Antifreeze Coolant is the same high quality red fluid that's found in all new Toyotas. Its unique formulation was developed exclusively to meet the specific requirements of your Toyota engine. Other benefits to using Toyota Long Life Antifreeze Coolant are:
• Will not clog radiators from silicone "gelling."
• Will not corrode aluminum surfaces like coolants that contain borate.
• Helps protect water pump seals.
