first time i change my oil myself
Old Oct 20, 2008 | 06:14 AM
thispecialk's Avatar
Default first time i change my oil myself
so i change my oil myself on the tc for the first time i already used the first 2 free maintenance service and they was asking around 300 for the third. i change the oil to mobile 1 syntetic 0w 20 and i used 4 bottles i think that 4quarts. my question is did i use enough cause i have 1 more bottle and also did i use the right oil cause somewhere here i read some people use 5 w30 or 5w 20 wats the difference
Old Oct 20, 2008 | 06:44 AM
cavalierkid888's Avatar
300$!!
The numbers relate to the oils viscosity. Lower the number the thinner the oil.
Old Oct 20, 2008 | 06:47 AM
SquallLHeart's Avatar
you have a manual... read it. 4 qts.
and 5w20 would be the standard.
Old Oct 20, 2008 | 06:48 AM
so did i pick the right oil im using 0w 20 mobile 1 syntetic or should i have gotten 5w20 or 5w30 and how many quarts do i use i bought 5
Old Oct 20, 2008 | 06:50 AM
i heard i should use royal purple but i only saw 5w 30
Old Oct 20, 2008 | 06:51 AM
I would suggest running 5w 20 seeing as your in HI, you probably don't get that cold of winters there. But I wouldn't worry about it just change it at your next oil change. And 4 quarts only, check your oil level with your dipstick if you feel you didn't put enough in.
you heard where.....?
Old Oct 20, 2008 | 06:52 AM
i read some post on scion life people use 5w30 why did they use that one
Old Oct 20, 2008 | 06:53 AM
2006 and below use 5w30...
i thought i told you to read your manual... or did you not receive one?
Old Oct 20, 2008 | 06:55 AM
i read the manual but like i said i notice people on scionlife talking about using 5w30
Old Oct 20, 2008 | 07:01 AM
Maybe they have a 06 or below...
Old Oct 21, 2008 | 05:42 PM
Tc4Eva's Avatar
Team ScionTific
I know that the 05's use 10w-30, it says on the oil cap, and in the manual. Dont mean to threadjack, but what oil filter did you use? Im gonna change my own oil this weekend but dont know which filter to use, there was a ton to choose from when i went to the store.
Old Oct 21, 2008 | 08:16 PM
i used k & n
Old Oct 21, 2008 | 08:47 PM
Tc4Eva's Avatar
Team ScionTific
Is there a certain size for the filters?
Old Oct 22, 2008 | 12:45 AM
yes..
and OEM Toyota filters... imo, are the best to use.
Old Oct 22, 2008 | 09:59 PM
Tc4Eva's Avatar
Team ScionTific
k. Guess Ill stop by the dealership tomorrow morning.
Old Oct 23, 2008 | 08:19 PM
AAG's Avatar
AAG
DeepSouth Scions
Originally Posted by SquallLHeart
yes..
OEM is not the best but they are good quality filers. I believe one of the best if not the best is AMSOIL EaO filters.
Old Oct 26, 2008 | 07:04 PM
kriswawa's Avatar
why 07 have to use 0w-20 ? it very expensive in poland. Can I use mobile 1 synt 5w-30 ? its she same engine as 05-06 tc !
Old Oct 27, 2008 | 01:20 AM
Tc4Eva's Avatar
Team ScionTific
They arent exactly the same, i believe the 07's have a very small amount more of compression, but the 0w will make it easier to start up on very cold days. I would recommend the 5w-20 if you absolutly want to use the higher weight oil, But Id say get it as close to factory recommended specs as possible.
Old Oct 27, 2008 | 01:25 AM
MrBurrito's Avatar
the "w" stands for winter not weight
