Tire pressure light
Old Oct 20, 2008 | 02:46 PM
SighOnTeeSee's Avatar
Default Tire pressure light
So I'm driving around, working on breaking in my new tires, when my tire pressure light comes on. I pull into a parking lot and get out, check all 4 tires twice, 33-34.5 psi on all of them. I drive home and go to bed, before I go to work I check again, pressure is still the same, but the light's still on. I'm thinking that I got some faulty TPMS sensors from tirerack, anybody have any other possible explanations?
Old Oct 20, 2008 | 05:46 PM
krazyscion's Avatar
did u reset the TPS?
if you know ur tire pressure is fine then u have reset ur TPS
Old Oct 20, 2008 | 05:58 PM
SquallLHeart's Avatar
i don't think you got ANY tpms sensors from tirerack...
you didn't take them out of your old wheels, did ya?
Old Oct 20, 2008 | 07:49 PM
10gxiong's Avatar
i got new falkens (stock tire specs) about 2 months ago. i set the tire pressure to the stock specs that were listed on driver side door and my light went off.
Old Oct 20, 2008 | 08:01 PM
^^ you buddy.. have an '06.
you don't have tmps sensors.. the "sensor" that you have goes off the ABS.
your statement does not help with the OP's situation.
Old Oct 20, 2008 | 08:53 PM
elpolakotc's Avatar
yeah i would say no sensors in those tires so the light will go on
Old Oct 20, 2008 | 08:58 PM
eastham08's Avatar
check the spare tire.. thats usually the one that sets my light off
Old Oct 20, 2008 | 09:00 PM
huslindan's Avatar
^^ haha second that
Old Oct 20, 2008 | 09:10 PM
rneel77's Avatar
Default TPS light
Make sure you check that all tires are within spec then reset the TPS. I had the same thing happen to me when I got my oil changed one time. Turns out they were over inflating my tires. The system runs off of a sensor that picks up a wheel that isn't rotating the same as the others. Thus tripping the light. Inflate to what the inside of the door says, and if that doesn't work use that tires recommendation.
Old Oct 21, 2008 | 05:21 AM
Paid 350 to have them install sensors so I hope they put some in lol, how would I go about resetting the TPS?
Old Oct 21, 2008 | 05:25 AM
equinox2355's Avatar
If they weren't your sensors, then the system wont be able to read them. If they just installed new ones, its the same as not having any sensors (to the ECU at least)
Old Oct 21, 2008 | 05:31 AM
Default Re: TPS light
you don't have a 2007+.... which have actual sensors INSIDE the wheels.
oh geeez... you paid $350 for sensors?? oh man.... the ECU doesn't know about them.. doesn't see them.. and don't know what they are...
the ECU is programmed to your stock sensors.... you know.. the ones that are still in your stock wheels.
Old Oct 21, 2008 | 05:34 AM
HEY THAT'S WHAT I SAID!
Old Oct 21, 2008 | 05:36 AM
tc-guy's Avatar
check to see if the air stems are metal. if they are then they are sensors. set the front to 32 psi and rear to 29 psi. the spares aren't full size so i don't believe they have tpms. once the tires are all set correctly turn the key to the on position and reset the tire pressure light (inside the glove box). press and hold button until light blinks 3 times then let go. it should go off after that. if it still doesn't go out after all of that then u most likely have a bad tpms. u will have to have a dealership shop check that out if thats the case.
Old Oct 21, 2008 | 07:50 AM
still no mention of the fact that he took the stock sensors out of his stock wheels though dude..
doesn't matter if he has new sensors or not in his new wheels.. the car won't recognize them.
Old Oct 22, 2008 | 03:29 PM
Here is a PDF file for the tire pressure sensor activation (assuming the ones that they installed are compatible with the toyota ECU)
http://tijil.org/Scion_TSBs/pd03806.pdf
Old Oct 22, 2008 | 05:50 PM
i doubt a run-of-the-mill guy off the street will have access to a Toyota scantool..
along with the fact this is to activate the stock sensors that.. i can only assume..
ARE STILL IN HIS STOCK WHEELS.
if he has the serial numbers for the new sensors though... only can a Toyota technician reprogram the ECU... but really... there's no easy way to go around it.
Old Oct 23, 2008 | 03:50 PM
Gmonroe80's Avatar
350?? did u go to the dealer?
Old Oct 24, 2008 | 06:45 PM
i'm pretty sure he bought them brand new from the place he bought his wheels..
thinking the new sensors would replace the old ones easily...
uhm.. gross misconcept if so
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
