dezod endlinks makin noise
Old Oct 20, 2008 | 04:35 PM
chintastictc's Avatar
Default dezod endlinks makin noise
is this normal since the install the sway bars are makin lots of noise it sounds like clicking...clunking....squeeking...like something is broken....but everything operates normally
Old Oct 20, 2008 | 05:58 PM
Griever's Avatar
Didja lubricate the bushings before you slapped the swaybar on?
Old Oct 20, 2008 | 07:44 PM
nodsetse's Avatar
Is there some reason you're not asking Dezod? Seems they'd know best.
I'd expect them to be noisier than stock since they use heim joints instead of rubber or poly bushings, that's often the price you pay for improved control.
Old Oct 20, 2008 | 08:06 PM
paul_dezod's Avatar
Scionetics
KAD
Try white lithium grease. Teflon lined heims are not sometimes the most quiet items in existence. As said perfectly prior, "that's often the price you pay for improved control."
Old Oct 20, 2008 | 08:56 PM
thanks for the help....it sounds like something is loose but i tripple checked everything and everything is tightned...ill try the grease tho
Old Oct 23, 2008 | 03:57 PM
these noises cant be normal lol.....i cant even turn the wheel without noise....does anyone else have these noises????i put my car on a lift (2 post) a million times...everything seems secure....i just want some other opinions
Old Oct 23, 2008 | 04:04 PM
diselement's Avatar
After puting in my endlinks ive also had some nasty popping and creaking. The creaking was resolved for a bit with the WD40 but it eventually comes back (like after a month or so) The popping i have no idea but it def doesnt sound healthy to me either. Ima put it back on stands and check again soon cause they might be installed slightly crooked
Old Nov 2, 2008 | 10:05 PM
Steventc07's Avatar
i'm having the same issue now. Just with one of the endlinks tho. I need to lubricate the joints and bushings. I have the rear sway bar set to the sitffest setting (hotchkis) and i am tempted to go back to the softest setting...but i love how my car handles
Old Nov 3, 2008 | 02:04 PM
paul_dezod's Avatar
Scionetics
KAD
Try white lithium grease on all bushings and the heims.
Old Dec 12, 2008 | 02:07 AM
Ryan99FL's Avatar
Scion Dynasty
perhaps a noob question, but has any thought been given to greasable heims? ie endlinks with zerk fittings on the heim joints?
maximthegreat
Jan 19, 2016 02:31 PM
alexbarspin
Sep 3, 2015 02:04 AM
RokGoblin
Aug 11, 2015 02:45 PM
Marialzga
Jul 31, 2015 05:38 PM
TinmanTC
Jul 12, 2015 07:53 PM
