Turbo Shaftplay?
Old Oct 20, 2008 | 11:05 PM
SoFloTC's Avatar
Default Turbo Shaftplay?
hey guys.. so my engine was taken out and the turbo was taken off and my shop said my turbo has alot of shaftplay.. what exactly is shaftplay and how bad is it?
Old Oct 20, 2008 | 11:16 PM
B_Real45's Avatar
Shaft play can be from side-to-side and/or in and out. Every turbo has a little shaft play. You don't want any in and out shaft play - but side to side is okay as long as the wheels are not touching the housings.
Old Oct 21, 2008 | 12:11 AM
kikcaffine's Avatar
I think it when the little bearing inside is broken.
Old Oct 21, 2008 | 01:37 AM
rozz-tC's Avatar
yeah pretty much what b real said, my old turbo had a little side to side shaft play but worked fine and never once caused an issue, ideally you want 0 shaft play but as long as its minimal you should be ok.
And yeah bearing wear can cause it, make sure its getting adequate oil and draining freely and dont do hot stops, make sure you let it idle for a min or so if you dont have a turbo timer before you shut the car off, its a pain in the butt but i ruined my last turbo because of it.
Old Oct 21, 2008 | 03:11 AM
TurboToyotas's Avatar
Have it taken apart and inspected by a professional. (ie if its a Garrett turbo send it to a PD (performance distributor)
Shaft play until accurately measured is all based on ones personal opinion.
It can be fixed easily and its affordable as long as its not a hint of some larger issues.
Get it inspected.
Regards-
Todd
Old Oct 21, 2008 | 03:14 AM
olaHalo's Avatar
Originally Posted by TurboToyotas
Have it taken apart and inspected by a professional. (ie if its a Garrett turbo send it to a PD (performance distrubitor)
Get it inspected.
Regards-
Todd
thought you died
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
