head or block swap
Old Oct 23, 2008 | 10:02 PM
lorthnu's Avatar
Default head or block swap
u know how people are always making Ls vtec's or crvtec's or even mini me's i was wondering if anyone has any swap ideas seeing as how u have to have big money to do a full engine swap in the box due to lack of space and complicated wiring! maybe even if you can swap the crank to stroke the motor or a stronger stock valve train
Old Oct 23, 2008 | 10:07 PM
jct's Avatar
jct
with lots of money you can drop a chevy 350 in there and convert it to rwd and some body already did that so yeah
Old Nov 4, 2008 | 11:05 AM
ElevationTC's Avatar
i always woundered that myself but dont really know much about other platforms. Be sick if we could use the gts head!
Old Nov 25, 2008 | 04:27 PM
Tamago's Avatar
why would it be sick??
the stock bottom end won't handle more than 6500rpm constant... so what's the point of a 2ZZGE head
i still think a well built 4EFTE is the answer to the xA/B woes
Old Jan 22, 2009 | 04:20 AM
UnSouled_xA's Avatar
What car runs a 4EFTE? Sorry, not to smart on our Toyota motors... still crossing the gap from a B16 civic hatchback.
Old Jan 22, 2009 | 04:23 AM
Tamago's Avatar
toyota starlet GT
Old Jan 22, 2009 | 04:27 AM
Thanks Tamago!
Old Jan 22, 2009 | 04:28 AM
Tamago's Avatar
no problem. 4EFTE's can be had for very short money (generally under 1000) and can be built to withstand 375hp. not bad for a 1.3L
Old Jan 22, 2009 | 04:31 AM
wait.... 375 from a 1.3? lol the power to size ratios always through me off. massive boost?
Old Jan 22, 2009 | 04:33 AM
Tamago's Avatar
seriously massive boost and a seriously built engine. probably $6000 in parts/labor..
but you can swap rods/pistons/injectors/fuel rail for about 1400 and make 275 easy
Old Jan 22, 2009 | 04:39 AM
swapping all that out, the rods/pistons/injectors/fuel rail, would that be a first step to the boost or building up for NA?
Old Jan 22, 2009 | 04:42 AM
Tamago's Avatar
the 4EFTE is turbo from the factory..
i forgot to mention you'd want a bigger turbo too lol my mistake
Old Jan 22, 2009 | 04:47 AM
doing a bit of google searching for more info on it. is it an easy swap?
Old Jan 22, 2009 | 05:05 AM
Tamago's Avatar
you'll have to fabricate at least one engine mount. you'll want to do a full standalone management. you'll need to run a return fuel line to the tank and you'll have to make custom exhaust..
so, no, not EASY easy.. but a better platform to build off of.
Old Jan 22, 2009 | 05:12 AM
Hmm... fabbing motor mounts and standalone management... sounds a bit much.. they need to ours easier to upgrade
Old Jan 22, 2009 | 02:48 PM
Tamago's Avatar
YOU are "they"
Old Jan 22, 2009 | 05:25 PM
lol I need to make our motor easier to upgrade? I may need some help.. Any power staying NA for us? Maybe new internals?
Old Jan 22, 2009 | 05:30 PM
Tamago's Avatar
the pistons are already 10.5:1.. i think a tune would do a LOT for the 1nz NA.. but boost will always beat it. i'm 9-10lbs and 155whp with 150wtq. not as much as many other boosted 1nz's but my budget just broke 1200 lol
Old Jan 22, 2009 | 05:35 PM
you spent 1200 and you're #'s are 155hp and 150tq?
Old Jan 23, 2009 | 01:52 AM
Cinderblock's Avatar
yep, hes a home grown blown setup lol. well technically not blown, but i wanted it to ryhme lmao, that man has done some awesome ish with his car lol.
