In box video 365Motorwerks Kit, Auto Box , 20-80mph
Old Oct 25, 2008 | 04:36 PM
365Motorwerks's Avatar
Default In box video 365Motorwerks Kit, Auto Box , 20-80mph
All right I have back to back 20-80(ish) runs on my box without and with boost. You'll have to click on the link I can't embed Vimeo but the quality is way better than Photobucket and YouTube!
http://www.vimeo.com/2056796
Old Oct 25, 2008 | 04:38 PM
coryjames's Avatar
sickness is this kit intercooled?
Old Oct 25, 2008 | 04:44 PM
Old Oct 25, 2008 | 05:11 PM
coryjames's Avatar
very nice what kinda numbers did you put down how did you deal with the oiling?
Old Oct 25, 2008 | 05:31 PM
139hp/129lbft
Check out the pictures here https://www.scionlife.com/forums/viewtopic.php?t=206270
Oil feed is off the sender and return is through the block.
Old Oct 29, 2008 | 09:04 PM
TheCCBox's Avatar
Nice dude i now wish i had a turbo already LOL!!!!
Old Oct 30, 2008 | 07:48 PM
paul_dezod's Avatar
Scionetics
KAD
Nice!!!!!!!!!!!
Old Nov 5, 2008 | 01:33 AM
greybox's Avatar
Clutch issues at all? You have quite a few miles on your car already too-right?
Nice.
Old Nov 5, 2008 | 03:09 AM
Nice.
I have an automatic so on those a tranny cooler and a fresh fluid and filter swap are a great idea and my tranny has over 211,000 on it right now! For the manual it all depends on condition and driving style, for example if you plan to run as hard as you can then by all means swap the OE clutch, @ 365 we offer ACT and CC upgrades that will fit the bill and if you want to get all crazy how about an Exedy Carbon Clutch? However if you have a low mileage box and drive fairly restrained then the OE will last but it should be put on your "next up" list of things to do. Thanks for your interest and let me know if there is any more info I can help with.
Old Nov 6, 2008 | 01:47 AM
Zombietime's Avatar
Looks like it knocks off about 6 seconds from 20 to 80 with the boost. Is that accurate?
Old Nov 6, 2008 | 01:55 AM
Absolutely, both videos are from the same car on flat ground and I started out in second gear. The tune can and will be better so once that is done it might come down a bit more. The added pull from the turbo seems to be in just the right spot!
Old Nov 6, 2008 | 01:57 AM
Zombietime's Avatar
So your kit is complete then? I have an 05 with a stick... 41k miles, stock everything but a header and springs. Other than a beefier clutch, would I need anything else? Would I need to get a tune after installing it? Essentially what i'm asking about is what are the little things that need to be done in addition to buying the kit?
Old Nov 6, 2008 | 07:50 PM
Clutch recommended, tune required. If you want gauges you will need to add those but otherwise you are good to go I even throw in a set of iridium plugs..
DJ_FroZone
25
May 30, 2019 07:17 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
hampton1100
May 28, 2015 07:32 AM
clickclickw00t
Feb 18, 2015 08:57 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
