Clifford 50.5x Remote start help please.
Old Oct 27, 2008 | 11:11 PM
8erBox's Avatar
Default Clifford 50.5x Remote start help please.
Hello all, new to the site here. I have gotten some great help here and now looking for help on a more specific problem. I did search a bit but found nothing addressing this problem.
Remote start will activate and crank the starter but the engine will not start. However if I leave the key in the ignition in the on position and use the remote start button it will turn over and run as it should.
Here is what I have hooked up:
Vehicle: 05' xB it did come w/Scion Security
Heavy gauge relay satellite connector
1urple (+) Starter output to starter (Starter side)
Black small gauge from Ign Switch (Starter side)
2:Green Starter input from ignition (Key side)
Black small gauge from Ign Switch (Key side)
3:Red (+) High current 12v input
White/Blue from Ign Switch
4:Orange (+) Output to accessory circuit
Blue/Red from Ign Column
5ink (+) Output to primary ignition circuit
Black large gauge from Ign Switch
6:Red (+) (30A) High current 12v input
7ink/White (+) Output to second ignition circuit
Black/Yellow from Ign Switch
8:Red/White (+) (30A) High current 12v
Everything else seems to function properly besides the remote start. I do have the hood pin switch, and neutral safety switch hooked up and those are not causing the problem because the remote start would not activate if that was the problem. I have tested all connections with a multimeter and they are good so it is not a bad connection. The tach wire is connected and was confirmed/learned by the solid LED. Could the factory Scion Security be causing this? I have tried removing the connections to the modules and still the same problem.
If the other wires that I have connected are necessary to post I can do that for more help.
Please confirm if I have any wire out of place or another wire that needs to be connected for the remote start to function fully.
Any suggestions would be great. Thanks in advance!
Old Oct 28, 2008 | 09:29 PM
8erBox's Avatar
Any ideas? Anyone? I want to button the B back up and get it on the road. I have the driver seat removed, upper dash removed, glove compartment removed, and steering column. Help me button this baby back up
Old Oct 29, 2008 | 09:38 PM
8erBox's Avatar
Problem solved. The guys over at 12v ended up helping me out. There was another wire from the ignition that needed to be hooked up. Green wire in the corner of the plug hooked that up to ign 1 output from the RS relay. So happy I can put this all back together now!
If anyone has a question feel free to PM.
Old Oct 30, 2008 | 04:43 PM
lorthnu's Avatar
glad you got it figured out i was going to tell you that there is no immobilizer on a scion and u might have missed that second ign wire! saw this post too late though
airmankevin1
Feb 14, 2018 01:23 PM
mw1957
Mar 16, 2015 06:00 PM
idriveanxa
Mar 8, 2015 12:03 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
BV19869
Dec 11, 2014 06:05 PM
