HID bulbs don't fit in the Sonars.
Old Oct 29, 2008 | 07:18 PM
burstaneurysm's Avatar
Default HID bulbs don't fit in the Sonars.
Okay, so my 9006 HID bulbs will not lock in to the housing of the Sonar projectors.
They're in there really tight, but they won't press in and twist.
I'm thinking it's not a big deal as the bulbs are definitely not going anywhere, but I was hoping someone else had this issue...
Old Oct 29, 2008 | 10:04 PM
IH8ONYU's Avatar
had this problem with my non hid 9006 bulbs when i got my sonars...
i just quick dremmeled the housing on the back of the headlights ands the bulbs went in and locked with a twist.
wierd though that you had no problem with the regular 9006 bulbs (i am assuming you had the sonars and used them for a while b4 you modded up to HID's)
Old Oct 29, 2008 | 10:12 PM
Actually, I was running H4 HID in my stock housings but got sick of all the glare, so I bought a set of Sonars and took an old set of 9006 HIDs from my roommate's tC.
Right now they're in there snug, but I'd like to do a bit of work and get them right.
The halo bulbs I was referring to were the ones that came with the projectors.
Old Oct 30, 2008 | 01:12 AM
Murbyrne's Avatar
MN Scions
dont mean to thread jack, but i was thinking of getting sonars...would there be any issue with my H4 H.I.D.s in sonars?
Old Oct 30, 2008 | 01:13 AM
SEXB909's Avatar
Default Re: HID bulbs don't fit in the Sonars.
hit up Sesh1975 on clubxb.com he has sonars on hids
Old Oct 30, 2008 | 01:29 AM
Yes there would. The H4 bulb does not fit. You need a 9006 base.
Old Oct 30, 2008 | 02:11 AM
Murbyrne's Avatar
MN Scions
roger that, thanks....
Old Oct 30, 2008 | 02:43 AM
Photowhore time!
Old Oct 30, 2008 | 03:40 AM
sdsnybny's Avatar
This has been around a few times
Try this before you cut your housings
The o-ring that comes with the 9006 hid bulb is to big (dia of rubber/length) use the set of o-rings that came on the 9006 non hid bulbs that were supplied with the sonars.
Old Oct 30, 2008 | 02:38 PM
I have the halogen o-rings on there now. I've been told that if I loosen the three screws around the retension ring I'll be able to twist them down and then retighten the ring.
Old Oct 30, 2008 | 02:48 PM
sdsnybny's Avatar
I took the ring all they way off (before i new about o-ring size issue)
be careful those screws strip out easy and a couple of mine were really tight for such a small screw.
Old Nov 13, 2008 | 06:16 PM
PETERY2KRABBIT's Avatar
i just put hid in my sonars without a problem
clickclickw00t
Feb 18, 2015 08:57 PM
scsteven
Jan 25, 2015 01:06 AM
mischman
Jan 14, 2015 06:07 PM
tc_Jake
Dec 31, 2014 01:45 AM
jaspercanda
Dec 28, 2014 10:09 AM
