DIY on how to take apart the new Easy Street struts.
Old Oct 31, 2008 | 04:35 AM
Gothbox's Avatar
Default DIY on how to take apart the new Easy Street struts.
here is how to take apart the new Easy Street struts to do what ever you need to do. I took mine apart to put on some new top plates to lower it more, I had EZ Baked make mine, but you could have yours made by whoever. This is just the process, and the results.
first you need to take this top nut off(19MM I think), you will need to use a hex key to hold the strut while you take the nut off.
After you remove the nut you will need to unscrew this part.
next you will need to remove this metal "ring", I just used my pocket knife to get up under the top edge, and get it going.
then just grab it and finish pulling it off, careful not to loose it.
now you can just lift the plate off. if you are replacing with an different one put it back on in between the two white plates like so.
and then just put everything back on like you took it off.
here is a before and after with the new plates on.
before, stock mounting plate.
After, new drop plate.
you may see more of a dramatic result but the frame braces under the car are on the ground on mine now, and I am only running 16s.
Old Nov 1, 2008 | 05:33 AM
andrewdustin's Avatar
wow, that looks really cool. if i only had the money.
I will continue to dream for now.
Old Nov 1, 2008 | 07:58 PM
1epoXyBox's Avatar
Looks Great, nice job!
Old Nov 5, 2008 | 12:01 AM
Box_Rod's Avatar
Nice job goth! Looks like you got about an inch of additional drop!
Old Nov 5, 2008 | 05:32 AM
Gothbox's Avatar
yeah at least. in that pic with my Rotas on, the frame braces are sitting on the ground, so I am not too sure how much more it has in it. I want to notch the frame more, but I need to weld reinforcements in it and all that stuff that I can't do. When I put my steelies on, the axels are sitting on the frame, even after the pinch welds have been cut flush with the frame. I also want to top mount the plates as well, I have to trim a little on the top of the strut tower first though.
Old Nov 5, 2008 | 04:15 PM
Sciond's Avatar
nice diy
Old Nov 8, 2008 | 07:52 PM
josheyxb's Avatar
you say if only you had the money well your in luck cause here is a diy by the all mighty randode on how to do it
http://www.clubxb.com/forums/f15/diy...asy-24986.html
joshey
Old Nov 9, 2008 | 07:03 AM
Big_hungry's Avatar
joshey
Now correct me if i'm wrong here but i though this thread by the all mighty GOTHBOX was about how to take apart the strut.
that's a good diy if you have a plasma cutter welder and other tools needed to make a plate. if you don't have that stuff just laying around the house then what good is that diy?
Old Nov 9, 2008 | 07:13 AM
^thank you, plus my comment was for the whole setup.
Old Nov 9, 2008 | 07:18 AM
Big_hungry's Avatar
yea i hear ya . i wish i had the money as well to do that to my box. One day i will but Ill be sure to save my money so i can first afford a plasma cutter welder and a grinder. then after i get all that maybe i can get me some bags for the box lol
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
Wrencher
Jul 29, 2015 01:38 PM
umnitza
Jul 25, 2015 07:54 PM
