DIY on how to take apart the new Easy Street struts.
here is how to take apart the new Easy Street struts to do what ever you need to do. I took mine apart to put on some new top plates to lower it more, I had EZ Baked make mine, but you could have yours made by whoever. This is just the process, and the results.
first you need to take this top nut off(19MM I think), you will need to use a hex key to hold the strut while you take the nut off.
After you remove the nut you will need to unscrew this part.
next you will need to remove this metal "ring", I just used my pocket knife to get up under the top edge, and get it going.
then just grab it and finish pulling it off, careful not to loose it.
now you can just lift the plate off. if you are replacing with an different one put it back on in between the two white plates like so.
and then just put everything back on like you took it off.
here is a before and after with the new plates on.
before, stock mounting plate.
After, new drop plate.
you may see more of a dramatic result but the frame braces under the car are on the ground on mine now, and I am only running 16s.
Originally Posted by Box_Rod
Nice job goth! Looks like you got about an inch of additional drop!
Originally Posted by andrewdustin
wow, that looks really cool. if i only had the money.
I will continue to dream for now.
http://www.clubxb.com/forums/f15/diy...asy-24986.html
joshey
Originally Posted by josheyxb
you say if only you had the money well your in luck cause here is a diy by the all mighty randode on how to do it
joshey
joshey
that's a good diy if you have a plasma cutter welder and other tools needed to make a plate. if you don't have that stuff just laying around the house then what good is that diy?
yea i hear ya . i wish i had the money as well to do that to my box. One day i will but Ill be sure to save my money so i can first afford a plasma cutter welder and a grinder. then after i get all that maybe i can get me some bags for the box lol
Subaru86
07-31-2015 04:33 AM
Subaru86
07-31-2015 04:00 AM
Wrencher
07-29-2015 01:38 PM
umnitza
07-25-2015 07:54 PM
