Cel light fix
Old Nov 3, 2008 | 11:19 PM
justin6969's Avatar
Default Cel light fix
i couldint find an answer so i juss threw up a topic but with the megan header that has the o2 sensor hole built into it do you need the cel light fix thing or does the predrilled o2 sensor hole don't throw a cel light? please if any one know's let me know so i can order it with the header thank's
Old Nov 4, 2008 | 12:55 AM
aryan13's Avatar
I guessing that the first port on the header is for the primary O2 sensor. Usually you get the CEL from the secondary O2 sensor.
Old Nov 4, 2008 | 02:10 AM
justin6969's Avatar
oh ok well just in case were would i get the Cel fix at >?
Old Nov 4, 2008 | 02:39 AM
aryan13's Avatar
PM InLikeFlint
Old Nov 4, 2008 | 09:55 AM
rjweitzel's Avatar
you need to install the cel fix on your spipe, that gets rid of the cel code if you are running an aftermarket header
Old Nov 4, 2008 | 11:20 AM
justin6969's Avatar
any site i can buy it from?
Old Nov 4, 2008 | 04:34 PM
rjweitzel's Avatar
just search "cel fix" on ebay
Old Nov 4, 2008 | 06:40 PM
Ihabia's Avatar
When I installed my AWheader the check engine light (cel) came on. I then went to install a couple of spark plug antifoulers in the O2 position of the S-pipe. Yes, I used two. Haven't had any problems since; it's almost been a year. Hope this helps...
Old Nov 4, 2008 | 08:01 PM
justin6969's Avatar
ya i just looking to see if any one with the megan header have to get the cel fix?
Old Nov 4, 2008 | 10:24 PM
rjweitzel's Avatar
you need a antifouler with any aftermarket header because it deletes your cat, it doesnt matter what brand
Old Nov 4, 2008 | 10:37 PM
justin6969's Avatar
ok well can i get it anywere beside's ebay i hate buying things off ebay
Old Nov 5, 2008 | 02:04 AM
aryan13's Avatar
Like I said, PM InLikeFlint for the CEL fix.
Old Nov 5, 2008 | 02:05 AM
justin6969's Avatar
i found 1 on ebay i guess ima go with that 1 its only 14$
Old Nov 5, 2008 | 05:57 PM
aryan13's Avatar
Those ones on ebay look like an antifouler that you can pick up from any auto parts store for about 5 bucks. You need to get an angled one or at least two antifoulers for it to fix the CEL. You get what you pay for. Those guys on ebay are scamming you by charging 3X what that part actually costs.
xBSciontist
Jun 18, 2019 03:06 PM
12xb
Nov 7, 2015 03:44 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
cid_mcdp
Jan 5, 2015 02:45 PM
