Remote Start on xB - HELP Fast Please
Old Dec 24, 2004 | 08:41 PM
wyldkard's Avatar
Default Remote Start on xB - HELP Fast Please
I am installing remote start currently and need help. There are 2 black wires on the ignition harness. 1 is Ignition and 1 is Starter. I need help figuring out which is which and I don't have my multimeter with me. If someone could please help out as to which one is in pin 4 and which one is in pin 6, I would greatly appreciate it.
Thanks,
-Z
Old Dec 24, 2004 | 08:50 PM
Big_Jim's Avatar
this is straight from the directechs website. hope it helps you out.
12volts wht/blue (40A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock blue/white - driver kick, 14 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock yellow/black (double pulse) - driver kick, 14 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/orange 5wi driver kick, 9 pin plug
Unlock Motor yellow/green 5wi driver kick, 9 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/white - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/red + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white/red - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Old Dec 24, 2004 | 08:58 PM
wyldkard's Avatar
I already have almost the same thing, I'm just wondering if it's going to mess something up if I accidentally wire the remote start ignition wire to the starter. Or are they interchangable?
-Z
airmankevin1
Feb 14, 2018 01:23 PM
mw1957
Mar 16, 2015 06:00 PM
idriveanxa
Mar 8, 2015 12:03 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
BV19869
Dec 11, 2014 06:05 PM
