Lowerig Springs for 08 xB
Old Nov 7, 2008 | 06:31 AM
Hybrid350GT's Avatar
Default Lowerig Springs for 08 xB
Looks like there are several springs to choose from, but which ones lower the car the most & the least?
Old Nov 7, 2008 | 06:43 AM
xseveredveganx's Avatar
Utah Scions
Ummm... Tanabe NF210's and DF210's.
Old Nov 7, 2008 | 02:56 PM
FromTheOld's Avatar
The Eibach Pro-Kit and TRD Springs lower the least, and I think the Hotchkis Springs/Sprint Springs lower it the most.
Old Nov 7, 2008 | 03:31 PM
CIONIDE's Avatar
Default xB2 spring drops
Eibach Pro-Kit the least, Sprint the most.
TRD
Front: 1"
Rear: 1.5"
Tanabe NF210
Front: 1"
Rear: 1.7"
Tanabe DF210
Front: 1.7"
Rear: 2.1"
Eibach Pro-Kit
Front: 1"
Rear: 1.2"
Eibach Sportline
Front: 1.2"
Rear: 2.2"
Hotchkis
Front: 1.375"
Rear: 2.25"
B&G
Front: 1.6"
Rear: 2.2"
Sprint
Front: 2"
Rear: 2"
Old Nov 7, 2008 | 09:49 PM
oh, perfect. Exactly what I was looking for. Thank you so much. Very helpful!
Old Nov 7, 2008 | 10:21 PM
CIONIDE's Avatar
Keep in mind that drop is only part of the story. For example; Eibach Pro-Kit & TRD have less drop on the rear than Tanabe NF210, but the NF's provide a softer ride and even out the jacked up rear end more to a level ride height with the front. Similarly, the Eibach Sportline & Hotchkis don't drop the front as much as the Tanabe DF210, but they both level out the ride height more than the DF's. It all depends on what you are looking to get out of your drop.
Old Nov 8, 2008 | 06:26 PM
whitebreadbox's Avatar
also keep in mind what you're going to be hauling around in the rear all the time. if you have a few subs/big box back there, you'll want one that will leave the rear "jacked" up to compensate for the extra weight...
Old Nov 12, 2008 | 09:12 AM
srb219's Avatar
Who has the cheapest price for the Eibach Pro-Kit? Thats going to be my next mod. Just wish we had some reasonable performance shocks out there to install at same time
Old Nov 12, 2008 | 10:56 AM
FromTheOld's Avatar
Your shock choices are Tokicos or TRDs, and you can get the Eibach Pro-kit for a good price at Tirerack
Old Nov 13, 2008 | 05:42 AM
bego's Avatar
I have been doing research on springs as well and found out you need to pay attention to the spring rate.
Old Nov 13, 2008 | 06:28 AM
CIONIDE's Avatar
And wheel width, and wheel offset, and tire size...
Old Nov 13, 2008 | 12:18 PM
FromTheOld's Avatar
Hard to do that when almost none of the manufacturers give you rates. Most are progressive so they don't have specific rates, but manufacturers don't even give you a range. The only way to tell if a spring has a high spring rate is by design (looking at them compared to other springs), which obviously isn't that accurate.
No one else on these forums seem to care about spring rate though, they just care about drop, so I doubt manufacturers will ever give out the information (unless you specifically ask them yourself). Low does not mean stiff, but everyone seems to think that. Example: NF210s are stiffer than DF210s. (look at Tanabe's website for the rates)
Old Nov 13, 2008 | 12:24 PM
srb219's Avatar
Good thread Old, I want medium drop with higher spring rates. Haul 200/300 lbs every day for delivery service. Would buy the Tociko's and install with springs but heard QA is not good. TRD's are just to much $$
Old Nov 13, 2008 | 06:22 PM
bego's Avatar
eibach pro kit sounds like a good spring for you srb219 if you ask me
Old Nov 15, 2008 | 01:39 AM
StylWagon's Avatar
hows the ride with the hotchkis? it looks just right for the look im after
Old Nov 15, 2008 | 08:24 AM
CIONIDE's Avatar
is your friend.
Here you go:
*Official Hotchkis springs drop thread*
https://www.scionlife.com/forums/viewtopic.php?t=218582
Old Nov 15, 2008 | 08:46 AM
srb219's Avatar
thanks bego. Any one out there running the Tociko shocks front and rear?
Old Nov 16, 2008 | 01:45 AM
bego's Avatar
Between reading that post Cionide just posted and all the excellent reviews I have read I am leaning toward the hotchkis
Old Nov 16, 2008 | 03:17 AM
Utah Scions
It's cause the Hotchkis are made with WIN! as opposed to the Tanabes being made with fail.
:D
Old Nov 16, 2008 | 04:31 AM
bego's Avatar
:D
