HELP, Weird popping clicking sound over passenger door
Old Nov 17, 2008 | 11:58 PM
CheapChic's Avatar
Default HELP, Weird popping clicking sound over passenger door
OK, can't stand it anymore. there is a popping clicking sound over the passenger door on the drivers side. I have looked behind the headliner and nothing is loose.
what gives anyone know.
please and thanks
it happens over bumps hard bumps.
Old Nov 18, 2008 | 12:24 AM
Invertalon's Avatar
Most likely the seatbelt rattling into the B pillar.
Just tuck the clip inside where the belt retracks inside the pillar and no more sound (if that is the issue).
Old Nov 18, 2008 | 12:40 AM
CheapChic's Avatar
I tried that already, it is comming from over the rear door on the roof portion
Old Nov 18, 2008 | 10:51 PM
CheapChic's Avatar
anyone, sound like the same as the A-pillar creek i had once on the 08
Old Nov 18, 2008 | 11:05 PM
Invertalon's Avatar
May I ask why you went from a 2008 to a 2009 xB?
Secondly, people have reported a B pillar creak appearing, similar to the A pillar one in sound, just different location. Maybe take it in and let them find it, IF you trust them.
Old Nov 18, 2008 | 11:07 PM
Jan06xB's Avatar
Try cleaning an lubricating the weather seals for the doors with a silicon spray. Only thing else in the liner is wires for the dome light.
Old Nov 18, 2008 | 11:13 PM
CheapChic's Avatar
I will try that
CheapChic's Avatar
I will try that. but it sounds metalic
Old Nov 18, 2008 | 11:14 PM
CheapChic's Avatar
I sold my 08 to a friend and like the car so much I got the 09
Old Nov 19, 2008 | 05:38 PM
Toastado's Avatar
Default Re: HELP, Weird popping clicking sound over passenger door
please and thanks
You're not alone, I have exactly the same problem.. its driving me nuts.
Old Nov 19, 2008 | 06:10 PM
thanhtran's Avatar
i also here it too! its on the passenger side towards the front of the car. i also notice a little springy noise by my speedometer/head unit area for my stereo..does anyone get that?
Old Nov 19, 2008 | 08:43 PM
shinobi's Avatar
Since the weather turned cold, I've been hearing a popping sound on my passenger side, towards the front. Don't know if it's the dreaded a-pillar creak or not, but it only happens on certain bumps. It almost sounds like the glass is loose or something. Weird. It wasn't so bad on my way in to work today. I guess if it gets worse, I'll have to take it in. *sigh*
Old Nov 19, 2008 | 08:48 PM
CheapChic's Avatar
Mine is not the A-pillar for sure. it is right over he passenger door. I was told it might the the air bag curtain.
I was told maybe a tsb is out for it.
Old Nov 20, 2008 | 06:49 PM
Jan06xB's Avatar
Ahhh a wonderful technology problem. Yeah I forgot you newer xBs have side curtains.
Old Nov 20, 2008 | 07:10 PM
808-213-503's Avatar
you got a sunroof, by chance?
Old Nov 21, 2008 | 01:16 PM
CheapChic's Avatar
NO
thanks
Old Nov 21, 2008 | 01:59 PM
Jan06xB's Avatar
Ya know the colder weather will cause some plastics to get stiff. Been reading about a rattle in the xB in the dash around the glove box and I never had it until last week when the weather started getting cold.
Good luck finding that little gremlin!
Old Nov 21, 2008 | 03:11 PM
ckd's Avatar
ckd
When I had my headliner out I tapped on the grommets that hold the side air curtains in place and I thought that was where the sound was coming from. I put silicone around the metal grommets but that didn't fix it. It sounds like its coming from the plastic piece that slides up and down above the seat belt adjuster in the B pillar. Its driving me crazy because mine does it on passenger and driver side sometimes.
Old Nov 22, 2008 | 04:58 PM
Jan06xB's Avatar
You know there are electric operated shoulder and seat belt tensioners in the columns which react to G forces and lock. You might try yanking on the belt when you hear that sound and see if the belts are locking. Being colder the shock absorbers get stiffer and it may be just enough to make a rough ride trip the tensioner.
Old Nov 22, 2008 | 05:51 PM
bego's Avatar
I cant hear anything when my deck is turned up and my sub is killing my ear drums.... But for real I had a rattling noise from my passenger side A-pillar and found it must have been a loose clip from the dealer...
