HELP, Weird popping clicking sound over passenger door
OK, can't stand it anymore. there is a popping clicking sound over the passenger door on the drivers side. I have looked behind the headliner and nothing is loose.
what gives anyone know.
please and thanks
it happens over bumps hard bumps.
please and thanks
Originally Posted by Invertalon
Most likely the seatbelt rattling into the B pillar.
Just tuck the clip inside where the belt retracks inside the pillar and no more sound (if that is the issue).
May I ask why you went from a 2008 to a 2009 xB?
Secondly, people have reported a B pillar creak appearing, similar to the A pillar one in sound, just different location. Maybe take it in and let them find it, IF you trust them.
Originally Posted by Jan06xB
Try cleaning an lubricating the weather seals for the doors with a silicon spray. Only thing else in the liner is wires for the dome light.
please and thanks
please and thanks
You're not alone, I have exactly the same problem.. its driving me nuts.
Since the weather turned cold, I've been hearing a popping sound on my passenger side, towards the front. Don't know if it's the dreaded a-pillar creak or not, but it only happens on certain bumps. It almost sounds like the glass is loose or something. Weird. It wasn't so bad on my way in to work today. I guess if it gets worse, I'll have to take it in. *sigh*
Ya know the colder weather will cause some plastics to get stiff. Been reading about a rattle in the xB in the dash around the glove box and I never had it until last week when the weather started getting cold.
Good luck finding that little gremlin!
Mine is not the A-pillar for sure. it is right over he passenger door. I was told it might the the air bag curtain.
I was told maybe a tsb is out for it.
You know there are electric operated shoulder and seat belt tensioners in the columns which react to G forces and lock. You might try yanking on the belt when you hear that sound and see if the belts are locking. Being colder the shock absorbers get stiffer and it may be just enough to make a rough ride trip the tensioner.
I cant hear anything when my deck is turned up and my sub is killing my ear drums.... But for real I had a rattling noise from my passenger side A-pillar and found it must have been a loose clip from the dealer...
