where is the speed sensor wire 08+?
Old Nov 21, 2008 | 06:23 AM
unxpectederror's Avatar
Default where is the speed sensor wire 08+?
im trying to finish up hooking up my f90bt in my tC. but cant find the speed senor wire .ive looked all around on here and i haven't been able to find out where it is on the 08+ models
ive only been able to find 05-06 which isn't the same as my wiring.
also is the reverse wire the same as the older years?
if you could help me i would appreciate it.
Old Nov 21, 2008 | 01:55 PM
BZinn1's Avatar
On the harness that goes to the waterfall there is a orange wire with a tiny white stripe,that is the one I got my signal from for the Avic.Seems there is also a pink and also a yellow wire that also have the signal in it.
reverse wire is the same as the other years and in the corner under glove box.
Old Nov 21, 2008 | 07:51 PM
well see the problem is that on my car there are 2 orange wires on the waterfall harness... both of which have silver dashes on them. also which pink or yellow wire are you talking about ? is it also on the same harness?
thanks
Old Nov 22, 2008 | 03:47 AM
BZinn1's Avatar
the wire I get the signal from is the orange one in the middle of the harness....the one by the side did not work on mine.
the reverse wire is in the harness behind the glove box.
let me see if I can find the post that tells where they all are.
Old Nov 22, 2008 | 03:49 AM
BZinn1's Avatar
here it is has pictures and everything.....it is what i used for my bypass and entire install.
https://www.scionlife.com/forums/vie...vic++installed
Old Nov 22, 2008 | 05:42 AM
thanks man your the best
Old Nov 24, 2008 | 10:21 PM
SquallLHeart's Avatar
there's also a yellow wire that shares the same plug that the steering wheel controls do that goes into the stock stereo.
i find that to be a much easier wire to get to... and it's right there.
streetracerr
Jul 11, 2015 09:52 PM
daniinpitt
Apr 4, 2015 08:07 PM
TCnewguy
Scion tC 2G ICE & Interior
11
Feb 22, 2015 04:18 AM
tha17
Feb 5, 2015 12:56 PM
DAHOZZMAN
Dec 16, 2014 06:48 AM
