Anyone use Car Ramps to change oil?
Old Nov 26, 2008 | 06:45 PM
Skeezix's Avatar
Default Anyone use Car Ramps to change oil?
Just wondering if anyone uses Car Ramps to change their oil. My dad owns a pair of old metal ones, but they are too tall for my standard scion. The front bumper will hit the ramps before the tire can drive up.
Does anyone know of any type of ramp with enough clearance? I don't mind having to jack up the front end a bit to reach the pan and filter, but i would rather have it up on ramps for security purposes.
___
Old Nov 26, 2008 | 06:53 PM
PeaNut's Avatar
Try placing wooden blocks in front of the ramp and driving up those to get onto the ramp.
Old Nov 26, 2008 | 09:04 PM
d0ugch0i's Avatar
i wouldnt recommend it cuz the car might fall down the ramp and onto your body. we wouldnt want that would we. lolz.
Old Nov 26, 2008 | 09:10 PM
beandip007's Avatar
I have the cheep big plastic ramps, and that works just fine. I am not lowered so it will work.
Old Nov 26, 2008 | 09:12 PM
SSQ's Avatar
SSQ
Yeah, I use ramps. It's the plastic ones from Walmart that costed like 30 dollars, and it's worked well over the years and it's rated for up to 7500lbs, no falling on people. Peanut's recommendation is a very good trick for cars that are lowered, and should work well for you.
Old Nov 26, 2008 | 10:05 PM
highvoltage1's Avatar
I am lowered and can do it without jacking it up or putting it on ramps. My oil bucket thing just fits under there. Its a lil tight but it can be done very quickly. I mean even two pieces of wood would make it much easier. So If you not lowered just reach up under there man.
Old Nov 26, 2008 | 10:26 PM
Chrisb319's Avatar
they work fine for me.
Old Nov 26, 2008 | 10:29 PM
speddlysmitt's Avatar
That Rhino ramps brand makes a ramp for low profile cars. no problems for me. They sell them at AutoZone.
__________________
Old Nov 26, 2008 | 10:47 PM
TeeCizzle's Avatar
Just Jack-Up the Front Passenger Side...Use a Jack Stand....Thats ALL you need to do an Oil Change on the tC!...
Old Nov 26, 2008 | 11:01 PM
Yanki01's Avatar
is it OK to use ramps for an oil change or even life the car up from the front. will ALL the oil be able to get out it doing it that way? it doesnt need to be flat?
Old Nov 26, 2008 | 11:07 PM
BZinn1's Avatar
a great way to do changes is to get 2 8' 2x8"wide boards and cut one in half and the other into 2" sections and screw them together...... makes a good 4" lift off the ground and easy to drive on and off......cost about $20....even on lowered car you can get at the pan and filter.
Old Nov 27, 2008 | 05:01 PM
yellowxhoodie's Avatar
use a jack and jack stands.
much safer.
Old Nov 27, 2008 | 06:45 PM
09tC_CB7's Avatar
Default Ramp Extensions
I bought a few years ago for my mom's car something called Ramp Extensions for the metal ramps. They are hard plastic the same width as the ramps about 2 feet long with metal pins that fit into the holes on the metal ramps to make sure they don't slip out when in use.
All it does is lower the angle by extending the ramp approach angle. Plus it makes it easier to get up on the rams. I would think they still sell them, but the store I bought them at went out of business years ago.
I haven't changed the oil on my tC because I prepaid all of my maintenance for 5 years, so I take mine to the dealer.
Edit: here they are: http://www.tracyvette.com/autoramps.html
____
Old Mar 31, 2009 | 08:40 PM
stillettoDSM's Avatar
Those Walmart ones are the BEST!
Old Mar 31, 2009 | 09:15 PM
cavalierkid888's Avatar
I just use a jack and jackstands, like yellow said it's the safest. If your lowered and don't have a low profile jack to get under just run the car up on a couple 2x4's to get the jack under there.
Old Mar 31, 2009 | 11:25 PM
BEazy's Avatar
I cheat, I have access to a 4 point lift. Call me lazy, but I kinda like being able to stand under the car with everything at eye level.
Old Apr 1, 2009 | 12:40 AM
shupes31's Avatar
how is being on jackstands with a smaller base on the ground safer then being on wide ramps with blocks in the back wheels?
Old Apr 1, 2009 | 12:51 AM
Brian_M1Autosport's Avatar
Banned for NON PAYMENT
if your super skinny just slide under and do it!
haha
i usually just jack up the front with a regular jack and sometimes put a jackstand (i know, if only sometimes thats dangerous) but i remove the filter and oil fast and put it down.
adorable
16
Mar 1, 2020 08:58 PM
05xbman
Aug 27, 2014 01:08 AM
SengTC3
Regional - Pacific Mid
Jan 4, 2009 06:06 AM
bsptc27
Aug 20, 2007 10:13 PM
mad_vtak
21
Nov 3, 2006 05:49 PM
