Nighttime brake lights and headlights out
Old Nov 27, 2008 | 08:26 AM
KC's Avatar
KC
Default Nighttime brake lights and headlights out
My lowbeam headlights and apparently my nighttime rear lights do not work any more.
I was soldering together a faulty wire in my headlights but didn't unplug battery...
I checked all the fuses. What else could be the problem?
Please help. How do I fix this?
Old Nov 27, 2008 | 08:34 AM
SquallLHeart's Avatar
what faulty wire?
you hope you blew just the fuse.. but each headlight bulb has it's own fuse.. if both lowbeams went out... you either really messed up something.. or.. uhh.. you really messed up something.
at which then you hope you need to replace a bunch of fuses.
Old Nov 27, 2008 | 04:12 PM
BZinn1's Avatar
you blew a fuse.........pull them out one by one and you will find it.
Old Nov 27, 2008 | 05:30 PM
KC's Avatar
KC
Default Not a fuse I checked them all in the engine bay
I checked all the fuses in the engine bay both low beam 10amp fuses were replaced yet still headlights didn't fire up. I can hear the sound of it firing up but no light bulbs are also brand new too. Is there another solution?
Old Nov 27, 2008 | 06:14 PM
seek professional help...
Old Nov 27, 2008 | 06:38 PM
Hyghgynx's Avatar
Default Re: Not a fuse I checked them all in the engine bay
Are headlight fuses also located in the 2nd fuse location to the left of the steering wheel? (I can't
remember and do not have my manual handy.) Cause I know that's where the TAILS fuse is.
Old Nov 27, 2008 | 07:24 PM
all the headlight fuses are in the engine bay.
Old Nov 27, 2008 | 07:32 PM
BZinn1's Avatar
tails are under the dash and headlights are under the fuse cover in the engine bay.find which one is the fuse going to the headlights if it has power at that and power past it then the relay for the headlights blew.That would be the next area to check with a DMM
Old Nov 27, 2008 | 08:41 PM
KC's Avatar
KC
Thank you sir. I figured it was the relay. It is 80 dollars though. I will look for the tail light fuses. Thank you again
xBSciontist
Jun 18, 2019 03:06 PM
mischman
Jan 14, 2015 06:07 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
crystaljukebox_com
Dec 16, 2003 08:34 PM
