Nology Wires and Engine Cover
Team No Limitz
Ok, So I have had these plug wires here for a while now and got bored tonight. Decided I would put them on and see what I could do to make them look decent. Let me know what you guys think. My wife says I take crap to far. LOL.. So I installed the plug wires and didnt like the way it looked by itself. So I trimed out the center of the engine cover and thought it looked ok. But still wasnt happy with it. So I took some plastic, heated it and bent it and plastic welded it to the cover. Now I am happy with it.
Team No Limitz
I have had these for over a year. Figured I might as well try them right.
Figured I would get a comment like that from someone.. Way to go MOD!!!!!
wooow
thats nice show off those nology wires
do those nology wires really makes a difference?
i've heard bad things about them.
so what do they really do anyways?
how long do they lasts?
i'm sorry for thread jacking
i'm asking so much question is because i was thinking of doing it also but not sure what kind of difference am i gonna feel.
thanx for any info being provided :D
the nogoly wires will actually hurt a bit considering the stock setup has the coil packs right on the plug (coil on plug)
adding those wires will add more resistance. they are more effective on vehicles that don't use the COP setup and had wires that were able to be replaced with the nogoly ones.
for this case, it's not a replacement... it's an addition.
Team No Limitz
Originally Posted by NoLimitzInd
Have YOU actually tested them or seen if you loose anything with them? If you have I would love to see some data. Not just cause you think so. Now I agree that the coil packs on the plugs make better connectivity. But I would like to see some data wether you loose anything by doing these. I need to do some dyno time so this might be one of those things that I mess with and see if it hurts and you loose power or if it just stays the same or gain. I have never seen any data either way. Now nology says you gain some. But every company out there says that about their products.
have YOU searched? i remember you asking about these wires back in march:
https://www.scionlife.com/forums/viewtopic.php?t=214044
and if you search some more, you can find plenty of reports about these wires.. you wanted data?? well this is called empirical data.
to start you out, i found this one thread from over 2 yrs ago:
https://www.scionlife.com/forums/viewtopic.php?t=143415
Team No Limitz
There is still NO PROVEN data that says they help or not. Just alot of people talking about why they would or would not work. I did read that thread completely and it has some good points in there, but even still says unsure if they would help or not.
This seems to be a ongoing issue where or not they do help or not. I guess the only way would be a actual dyno run to see if they do anything or not.
Team No Limitz
Ok, so I went and drove it today.
No noticeable difference at all. No more no less. So I do not think these wires make it worse at all, nor do they make it better. Only a true dyno test would say for sure. I did alot of different tests really.
Full stop to really getting on it.
Rolling about 20 and getting on it.
Rolling about 50 in 4th and gunning it.
Like I said no noticeable difference at all. So I will agree with SquallLHeart , these are not a upgrade really to the system but maybe more of a addition.
Team No Limitz
I dont think it will stay. It was more of a "lets play around with some of the extra stuff I have laying around"
Then it got to a bashing the plug wires. LOL
Team No Limitz
I thought about the toober... But it dont really fit the look I have going. So I ordered the CF engine cover. Should be here in the next couple days.
2fixA
33
07-30-2004 03:13 AM
Besk_one
11-17-2003 09:28 PM
