Antifouler question
Old Dec 4, 2008 | 01:18 AM
SlimJim07's Avatar
Default Antifouler question
i got my megan racing headers and i was gonna do the antifouler trick but somebody i know did it to his scion and he said it makes it run rich...whats that mean?
Old Dec 4, 2008 | 02:02 AM
ESEMRFOZZ13's Avatar
Default Re: Antifouler question
just buy one from "inlikeflint" on here, it works 100% and is a solid desisgn.. rich= to much fuel / lean= not enough fuel. i've got a header but never saw it go rich. get a dme header from option2 in la puente for cheap.
Old Dec 4, 2008 | 02:11 AM
08TeintC's Avatar
^^^^ What he said =D..
Old Dec 4, 2008 | 02:18 AM
draxcaliber's Avatar
if that somebody you know installed an anti-fouler and ran rich, then they are a retarded because it probably means they installed the anti-fouler on the primary o2 sensor (the a/f sensor). they are supposed to install it on the secondary o2 sensor to trick it into thinking that the catalytic convertor is still present and functioning.
the secondary o2 sensor has no impact on the cars a/f ratios.
Old Dec 4, 2008 | 02:22 AM
CSOCSO's Avatar
get 3 antifouler 2 wont work! the CEl will come back on the highway!
Old Dec 4, 2008 | 03:02 PM
SlimJim07's Avatar
yea he said that when the gas burned it would smell bad and black smoke would come out lol
Old Dec 5, 2008 | 02:45 AM
well of course it smells bad, you removed the cat
Old Dec 5, 2008 | 03:04 PM
SlimJim07's Avatar
so doing this trick will not hurt your car in any way??
Old Dec 5, 2008 | 06:47 PM
okay...pay attention here, there are two oxygen sensors in our cars exhaust system.
the first one is on the exhaust manifold before the catalytic convertor. this is the a/f sensor. it reads the a/f ratio and feeds the information back to the ECU to make adjustments. when you swap your header, you just put this one directly back on the header.
the second sensor is on the s-pipe after the catalytic convertor. the job of this sensor is to simply detect of the primary catalytic convertor is present and still doing its job of cleaning up your cars exhaust emissions. this is the sensor that you trick using some sort of antifouler or CEL eliminator or whatever. this sensor has absolutely no bearing on what your engine does. it just triggers a CEL if it thinks your catalytic convertor has failed.
take it from me, i've been running the weapon-r header for about 9 months now, my a/f's are darn near perfectly stoic, and i'm not spewing out black smoke. even when i had fully unrestricted 3 inch exhaust, i didn't spew black smoke.
if your friend is running rich and spewing out black smoke, there is something else going on with his engine.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
