what's this for???
Old Dec 17, 2008 | 05:58 PM
AlexOnyx's Avatar
Default what's this for???
I ended up getting a different color tC, (now I have white!!) and where the optional switches go (fog lights, scion security, etc) there's what LOOKS to be the switch for the lights that go in the footwells.
However, when I looked under both foot areas, I didn't even see a spot for the cathodes to go. Also, when I opened my fuse box under the streering wheel, the switch I'm talking about has 2 red wires coming out of it. Each lead under the wire covers next to where you step when getting in the car (hope i made that clear enough)
Any ideas???? Turning it on & off does nothing as far as I can tell, but they obviously go somewhere!
Old Dec 17, 2008 | 06:04 PM
CarbonXe's Avatar
First off, good job on getting white, it's obviously the best tC color.
Do you have the illuminated door sill enhancements?
Old Dec 17, 2008 | 06:13 PM
AlexOnyx's Avatar
I do not. Mine is a 2005 model, regular door sills.
Old Dec 17, 2008 | 06:16 PM
CarbonXe's Avatar
Is it a toggle switch or a button switch? My 05 came with the footwell illumination and it had a 3 stage button switch (both on, driver only, both off).
If the wires only go to the fuse block, then it sounds like it's just pre-wired for something.
Old Dec 17, 2008 | 06:20 PM
AlexOnyx's Avatar
It's a toggle switch with either on or off. Also, there's something hanging that's not plugged in in my fuse box. I plugged it in, no difference in anything. I'll take a picture in a few minutes to better show, because i'm totally baffled.
Old Dec 17, 2008 | 06:22 PM
CarbonXe's Avatar
Maybe someone had something installed and took it out, and just left the switch there.
Also, the lights are just zip tied somewhere in the footwell. There isn't a specific designated location for them.
Old Dec 17, 2008 | 06:26 PM
AlexOnyx's Avatar
I figured as much regarding the lights, but I don't even see anywhere for the lights to be connected to anything.
Old Dec 17, 2008 | 06:31 PM
CarbonXe's Avatar
There are plastic panels that they poke through. Then they kind of just throw the light on it and zip tie it lol.
If you're planning on doing them, I suggest just buying some real cathodes and doing it, because the lights they have are terrible. They're not even cathodes...it's a cluster of LEDs at the and a long tube to spread the light. I swapped it out for 12" cold cathodes and the lighting dramatically increased.
Old Dec 17, 2008 | 07:35 PM
O5_TRD_tC's Avatar
yeah the OEM LED kit sucks!
Old Dec 18, 2008 | 01:38 AM
crg5990's Avatar
could it be a switch for fog lights that arent there?
Old Dec 18, 2008 | 03:08 AM
AlexOnyx's Avatar
I went to get a new key for my car and asked the people there if they could figure it out. Turns out, I have street lights!!
Now the problem is, they don't turn on... Any help with that?? Be nice to see what they look like when on. There are 2 red cords connected to the back of the switch that both go under the door sills, there are lights under the car, and theres a black cord that was unplugged. After plugging it into the back of the switch, they still don't turn on.
Ideas/thoughts? Thank you to all of you who have replied so far!
Old Dec 18, 2008 | 03:18 AM
x_Batman_x's Avatar
pics please
Old Dec 18, 2008 | 03:27 AM
Nastos's Avatar
cant help if we cant see lol
Old Dec 18, 2008 | 03:54 AM
AlexOnyx's Avatar
I will definitely get pics up in the AM, it's freezing outside. So much for California warmth, hah!
Old Dec 18, 2008 | 05:40 AM
SquallLHeart's Avatar
where in norcal are you? i can look over the car with you..
the dealership people wouldn't really be able to help you out as much as i can.
it's what you get when you buy a used car.... random stuff that you don't expect.
Old Dec 18, 2008 | 05:56 PM
AlexOnyx's Avatar
I live by Stockton and work up in Sacramento, where are you located?
(And as a sidenote, does anyone know how to or how much it'd be to fix my cd player cover? It doesn't spring open.)
Old Dec 18, 2008 | 06:29 PM
ohh.. i'm in the south bay..
to fix your cover? depends.. if it's broken.. it's broken.. probably missing a piece... at which then you would need to find that piece or replace the thing..
(and again with the whole thing about buying a used car..)
Old Dec 19, 2008 | 02:42 AM
x_Batman_x's Avatar
well you could replace the whole door for about $105: http://www.trademotion.com/partlocat...layCatalogid=0
.....orrr get a tCover! : http://tcover.net/
Old Dec 21, 2008 | 09:14 PM
highvoltage1's Avatar
Hey anyone got the tCover? I took my door out and cant figure out how to get it back together and may be missin a few of the components to make it fully functional. Will the tCover work without all the stock springs/gears watever. Or do i need a actuall assembly that works? Anyone know.
Old Dec 22, 2008 | 12:07 AM
the tCover removes the spring part of the mechanism. so it would install fine on yours.
