rear passenger window problem
Old Dec 30, 2008 | 08:17 PM
prototype80's Avatar
Default rear passenger window problem
I have had my 95 xb since 04, the thing has been a great car but here over the past ear a weird problem has been occurring with the rear passenger door window. I live in and during the summer when it heats up, the passenger side rear window absolutely refuses to roll down, I tried numerous times and nothing but as soon as the temp drops in the fall and winter the thing will roll up and down like it has no problem. I haven't a clue as to what can be causing this, all the other windows roll up and down with no issues year round. What do you guys think could be causing this, I am not an electrical genius at all. I appreciate any info i can get. I have taken the panel off and checked the connections but everything is as it should be. this just really confuses me.
Old Dec 30, 2008 | 09:55 PM
IH8ONYU's Avatar
i have a similar problem with my rear ds window... when it gets real hot out, the window will roll down about 2 inches and then stops...
if i try to roll it down again, the same thing happens...
i have to press the butting 5-6 times to get the window down completely..
if i hold the button down, same thing happens...
i thought it might be a faulty window module, but i pulled the window modules from the alarm, and no better luck..
if anyone has ideas or suggestions, i would be glad to hear them
i have gone to the dealer when i was covered under warrenty, and they replaced both window motors and both rear tracks, but the issue keeps coming back each summer, only on the ds rear window... trippy....
now i park with the ds facing the shade on hot days and i try to leave the windows cracked to vent during the day.
Old Dec 31, 2008 | 03:33 AM
andrewdustin's Avatar
same here guys,
I noticed it a couple years back when i tried to roll the window down on an extraordinarily hot day and it would not go down. it only has happened maybe once or twice with me but still confusing.
Old Dec 31, 2008 | 08:24 AM
is there any way we can contact toyota maybe tolet them know of this problem, if it is happening to three of us then i am sure it has happened to others. I just wonder how wide spread this problem is
Old Jan 5, 2009 | 04:01 AM
TypeX's Avatar
In summertime the glue holding the rubber trim comes loose on my xB and wedges the window closed.
Needless to say i just keep the AC on ;)
Old Jan 6, 2009 | 12:53 AM
Tannerb's Avatar
Try opening the slamming the door closed a couple times while holding down on the window switch. Let me know if it goes down. Toyotas are notorius for creating a vaccum inside the door the pulls the seals against the window.
Old Jan 6, 2009 | 12:59 AM
colinMAC1410's Avatar
my rear passenger side recently became stubborn too...when its rolled down completely and i try to bring it back up it goes extremely slow, then when it reaches a certain point it then goes up quick... confusing and a little annoying too
Old Jan 6, 2009 | 01:00 AM
TypeX's Avatar
you can use Silicone lubricant on the tracks and it speeds it up dramatically.
It should be used every month or so on all 4 tracks
Old Jan 6, 2009 | 04:50 AM
bluebox_02's Avatar
I had a similar problem wit my last xB, try taking the door panel off and see if there is any weather stripping getting caught in tha track. If so just use sum silicone to hold it back in place
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
pier0723
Dec 3, 2014 03:38 PM
iglooxb
Nov 6, 2003 05:42 AM
