19 inch rims and lowering
Old Jan 5, 2009 | 03:50 PM
dakichtc05's Avatar
Default 19 inch rims and lowering
i found some 19inch rims on craigslist and i want to lower my car as well but i figure if i do that it would rub severely. so i decided to come here and ask the experts
edit: here is the link on the rims/tires http://atlanta.craigslist.org/pts/951018175.html
Old Jan 5, 2009 | 04:29 PM
Lil_Deuce_tCoupe's Avatar
Check this out, see if it helps (before everybody flames you for not searching);
https://www.scionlife.com/forums/vie...highlight=fits
Old Jan 5, 2009 | 05:44 PM
dakichtc05's Avatar
thanks a lot, i was thinking about dropping it but then i talked to my friend and with a 19inch rim like that it would take away al l the gap between the body and wheel, thanks for your help
Old Jan 5, 2009 | 09:04 PM
That's what you want - no gap! Here's mine with TRD 19s, and Hotchkis springs. Second pic is on 18s.
As that chart shows you, offset and tire size are the most important factors in determining if you'll rub, depending on how severe the drop is. You can go with a mild drop (like TRD springs) and not have any rubbing issues at all, if that's your main concern.
But by all means, drop it - almost everyone on here will tell you that should be one of the first mods on your list. The tC looks so much better dropped - stock looks like a 4 X 4.
Old Jan 5, 2009 | 10:51 PM
tcfire's Avatar
your on hotchkis? it looks way to low on the rear.
Old Jan 6, 2009 | 05:16 AM
dqlostsoulz's Avatar
Here is the new and improved chart.......
https://www.scionlife.com/forums/viewtopic.php?t=231578
Old Jan 6, 2009 | 05:51 AM
dakichtc05's Avatar
thanks for all ur help!
Old Jan 6, 2009 | 06:16 AM
tcCALI's Avatar
actually it looks exaclty where its suppose to be.
Old Jan 6, 2009 | 11:36 PM
tcfire's Avatar
mine looks a little higher.
skruff
Scion tC 1G Wheel & Tire
Mar 16, 2015 06:16 PM
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
Mar 14, 2015 01:56 AM
Scion0814
Feb 12, 2015 01:41 AM
LoqT
Nov 11, 2003 01:02 AM
BlueBox
18
Oct 1, 2003 12:58 AM
