water temp sensor in radiator drain plug
Old Jan 7, 2009 | 07:55 PM
dwn4cause's Avatar
Default water temp sensor in radiator drain plug
I was wondering if a water temp sensor could be installed into the drain plug of the radiator using some adapters. I know they make the housing where you cut the radiator hose and slide on the housing and srew in the sensor, but I was looking for alternatives first. Thanks
Old Jan 7, 2009 | 08:25 PM
thendawg's Avatar
i always just thought why not tap the head at the return?
Old Jan 7, 2009 | 11:13 PM
Ace83's Avatar
Ronin Scion
it should be fine as long as the thread is the same.. im thinking of doing that when i get my sensor, hopefully it will fit
Old Jan 7, 2009 | 11:58 PM
blown_xa's Avatar
http://www.ptuning.com/html/search-r...odel&Brand=gre
just split the radiator hose and your done.
Old Jan 8, 2009 | 01:21 AM
yamaha16bw's Avatar
Or save alot of hassle and get a scan gauge.
Old Jan 8, 2009 | 04:01 AM
thendawg's Avatar
Haha why yes - thats why i want a scanguage - and it seems it can view iat temps from the maf :D i plan on having my maf in a blow thru setup when i get eveyrthing back together so id give me a good reading of what my iat is at the tb
Old Jan 8, 2009 | 04:52 AM
yamaha16bw's Avatar
Yup it displays intake temp from the maf. You get alot for your dollar with a scangauge.
Old Jan 8, 2009 | 01:20 PM
Ace83's Avatar
Ronin Scion
I have the scangauge and it does a great job.. The water temp sensor im trying to tap is for my thermofan relay.. since the mishimoto drain plug isnt good anyways im planning to just replace it with a threaded sensor
Old Jan 19, 2009 | 04:59 AM
Ace83's Avatar
Ronin Scion
Ok the drain plug on the mishimoto is 1/2 -18 pitch, I found this
http://store.summitracing.com/partde...5&autoview=sku
I can use this reducer for my 3/8 NPT water sensor.. Not sure about the stock size i'll take a look.. I like the idea of using the rad, it looks cleaner
Old Jan 20, 2009 | 03:09 AM
OuterHeaven's Avatar
Well the only problem I see with that is the drain plug is at the bottom of the radiator. That is where the cooler coolant will be which may give you a false reading. This depends on what you want to do. I personally would not do it.
Old Jan 20, 2009 | 03:34 AM
crush02342002's Avatar
the mish has a top and bottom drain plug if i remember correctly, and i dont think you would want it at the top either cause an air bubble may throw the reading off. On the bottom makes more sense to me, you gotta think that the water is constantly being circulated throughout the radiator via the water pump so its not like the bottom could be much cooler if at all.
Old Jan 20, 2009 | 03:41 AM
Ace83's Avatar
Ronin Scion
Im putting it on the top drain plug
DaBlackBox
134
Apr 10, 2022 02:04 PM
dinkjs
35
Apr 7, 2006 06:34 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
Minsk99
Mar 23, 2004 05:46 AM
Futureicon
Mar 22, 2004 01:02 AM
